Are Extra Non-Planck Dimensions Possible and What Could They Mean for the LHC?
  • Thread starter Thread starter bcrowell
    Dimensions
bcrowell
Staff Emeritus
Insights Author
There is the possibility that spacetime has more than 4 dimensions, and that the additional dimensions are curled up not at the Planck scale but at some larger scale. There has been some discussion that if these extra dimensions exist, then the LHC might produce microscopic black holes (which would presumably evaporate immediately). I'm interested in getting a broad overview of what this is about, and would be grateful if anyone could point me to a review paper or post any information here.
Is there any physical motivation for assuming these extra dimensions? GUTs?
What fixes the scale of these dimensions? Empirically, it presumably has to be less than the de Broglie wavelength corresponding to a TeV or something, since that's the scale we've probed already. Is there some theoretical motivation for fixing this scale at some value? Is there a hypothetical unification that occurs at some energy higher than the electroweak unification energy, which is ~100 GeV?
In a classical theory, dimensions with wrapped-around topology violate Lorentz invariance (since there's a preferred frame in which the circumference has minimum Lorentz contraction). Would preexisting tests of Lorentz invariance have been blind to this, since it occurs in a dimension they can't detect? I'm not specifically interested in Planck-scale physics here, but as a side note, I assume that string theory somehow dodges this issue, since string theory has Lorentz invariance baked in; is there any elementary way of seeing that the Lorentz-violation argument above *doesn't* apply to string theory?
Is there any reason for disliking the idea, other than "who ordered that?"
If the LHC did produce microscopic black holes, would there be any clear experimental signature of that?
Thanks in advance!
-Ben
[EDIT] Re the side-note about string theory -- if the circumference of a wrapped up Planck-scale dimension could be Lorentz contracted, it seems like you could make it Lorentz contracted by any amount you liked. You could contract it to 10^-100 of the Planck scale. Obviously that would be a problem, since there aren't supposed to be observable lengths below the Planck scale, are there?
As you probably kniow Lisa Randall, Harvard, has done work on large extra dimensions...and discusses them in her book WARPED PASSAGES, ESPECIALLY CHAPTER 19 PAGE 362no math...Maybe you can find excerpts online.
She mentions related work of Arkani-Hamed, Dimopoulos and Davali.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
