Calculating Flow Rate in a Varying Diameter Pipe: Oil & Water Density
The discussion focuses on calculating the flow rate of oil in a pipe with varying diameters of 100 mm at point A and 150 mm at point B, given gauge pressures of 126 kN/m² and 140 kN/m², respectively. Participants recommend using Bernoulli's equation, acknowledging the need for assumptions such as inviscid flow. The challenge lies in determining the velocities at both points, as the user has two unknowns. The formula for flow rate, Q = (1/4)(π)(d²)(v), is also mentioned, highlighting the interdependence of flow rate, diameter, and velocity.
  • Understanding of Bernoulli's equation and its assumptions
  • Knowledge of fluid dynamics principles
  • Familiarity with calculating cross-sectional areas of circular pipes
  • Basic algebra for manipulating equations
  • Study the derivation and applications of Bernoulli's equation in fluid mechanics
  • Learn how to calculate flow rates in varying diameter pipes
  • Explore methods for determining velocity in fluid flow problems
  • Investigate the effects of pressure differences on flow rates in pipes
Engineers, fluid mechanics students, and professionals involved in hydraulic systems or fluid flow analysis will benefit from this discussion.
ATHMechanical
Flow Rate through a pipe!
Oil flows along a horizontal pipe which varies uniformly in section from 100 mm diameter at A to 150 mm diameter at B. At A the gauge pressure is 126kN/m2 and at B 140 kN/m2. Find the flow rate in litres per second and kilograms per second. The density of water is 1000kg/m3 and the relative density of the oil is 0.8. could anyone help me find a possible solution to this Q? Thanks.
It all kind of depends on the things you can safely assume. Try Bernoulli's equation if you are able to assume all the prerequisites for it (e.g. inviscid flow, along a streamline, etc). Also, try showing a little more work you've done next time and you might get a better response.
I have tried Bernoulli's equation already but I need to find velocity at point A and B. Bernoulli's therom will only let me find one velocity if I have the other, but I have two unknowns. I am also assuming from the Q, it mentions the diameter of the pipe at point A and B which would therefore make it a circular pipe, and to calculate Q you need the cross-sectional area if I am not mistaken.
You may also calculate the Flow Rate by => (1/4)(3.14)(pipe diameter^2)(Velocity)
But I do not have the velocity. From this formula you can change it around to find Velocity but once again I do not have the Flow Rate.
Could you please help start this question...maybe I need two equations, to find velocity and area 1st and then use Bernoulli's therom to find flow rate.
Also thanks for your reply "timthereaper".
ATHMechanical.
  • · Replies 56 ·
