Dixon Statistical Test: Deriving Density Function
  • Thread starter Thread starter mpv55
    Statistical Test
The discussion focuses on the Dixon method for identifying outliers in normally distributed data, specifically detailing the critical value equation and the density function for extreme values. The critical value is defined as r01 = (xn - xn-1) / (xn - x1), while the density function involves a complex expression that includes factorials and integrals. Participants express difficulty in interpreting the LaTeX formatting, suggesting that using underscores for subscripts may improve clarity. There is a request for further explanation of the density function's derivation or references for better understanding. The conversation highlights the need for clear mathematical notation in statistical discussions.
mpv55
Recently, I was reading the Dixon (Annals Math. Stat. 22, (1951) 68-78) method for extreme (outliers) values. He considered that there are n ordered values (x1, x2, ...xn) of an analytical measurement. The values belong to a normal distribution. He defined two equations:
1. For Critical value
r01=\frac{x<sub>n</sub>-x<sub>n-1</sub>}{x<sub>n</sub>-x<sub>1</sub>}
2. The density function for x1, xn-1, xn is
\frac{n!}{(n-3)!}f(x1)dx1(\oint<sub>x<sub>1</sub></sub><sup>x<sub>n</sub>-1</sup>f(t)dt)n-3 f(xn-1)dxn-1f(xn) dxn
I will appreciate if someone explains the derivation of the density function or site some reference which explains it.
Thanks
Mixing in the "SUB" tag in between LaTex expressions seems to screw up the LaTex display. I can't make out what the density function is supposed to be. Can you revise it using the underscore ? (such as using the notation x_{n-1} for x with a subscript of n-1).
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
