Perimeter and area - need explanation
The discussion explains the calculations for the perimeter and area of a rectangle with dimensions a=2 and b=5, resulting in a perimeter of 14 and an area of 10. It highlights that a rope of length 14 meters can form a circle with the same perimeter, but the area of this circle is approximately 15.597, demonstrating that area and perimeter are distinct concepts. The conversation raises questions about measuring land, particularly when boundaries are irregular, and emphasizes that area is the preferred measurement for property to avoid misleading representations. The importance of area over perimeter in real estate is underscored, as buyers prioritize usable space rather than boundary length. Understanding the difference between area and perimeter is crucial in land measurement and property valuation.
PeteCA
Dimensions of rectangle are a=2 and b=5.
Perimeter and area P=2a+2b=14 and A=a*b=10
If we take a rope of length l=14m, encircle the rectangle and connect the ends we will have the same perimeter.
Now we take this rope and make circle of it, this circle will have the same perimeter of rectangle P=14.
Radius is r=(14)/(2*pi)= 2.228
Area of circle will be A=r*r*pi=2.228*2.228*pi=15.597
Why area of circle A=15.597 is not the same as area of rectangle A=10 ?
Mathematics news on Phys.org
Because area is not the same as perimeter. Take that circle of yours and crush it flat (well, almost; you can't really crush it into a line...); it now has ~zero area and the same perimeter. Incidentally, it's possible for a figure to have finite volume and an infinite perimeter.
Then why is land mesured in area and not perimeter, every mesure will give different results.
Is there a formula or easy way to mesure land if boundaries are like potato.
Because no one cares what the perimeter is, and no one wants to end up buying property with zero square feet because some sales rep was clever in advertising the place.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
