What is the scientific explanation behind the functioning of a waterpipe?
  • Thread starter Thread starter Moneer81
    Physics
A waterpipe, also known as hubbly bubbly or hookah, is a smoking device that uses flavored tobacco and operates differently from a bong. It features a bowl for tobacco covered with aluminum foil and heated by charcoal. The smoke is drawn through a stem submerged in water, which cools and filters the smoke before it reaches the smoker. When inhaling, a pressure drop occurs above the water, allowing smoke to travel down the stem, through the water, and up the tube to the mouth. This process delivers cooled smoke, although it still contains harmful substances.
Moneer81
Hey,
A waterpipe (alsno known as hubbly bubbly, hookah, shisha) is an oriental smoking device, that uses flavored tobacco (different than a bong, which is used to smoke illicit drugs). It consists of several parts: the head where the tobbaco sits, and is usually covered by aluminum paper where a piece of hot charcoal sits. The smoker inhales through a pipe but somehow that is connected to a water container that bubbles (and hence the name hubbly bubbly) as you inhale. Has anyone seen it or know how it works? I own one and I haven't been able to figure it out...
There is a stem attached to the bottom of the tobacco bowl which is submersed in the water. The ends of the tubes through which you draw the smoke are in the closed water chamber above the surface of the water. When you draw on the tube you lower the pressure above the water. Since the bowl is at atmospheric pressure air (containing smoke) travels down the stem of the bowl passes through the water and up to the mouth. Delivering the cooled deadly gas.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
