Where Can I Find an Affordable Vibrating Sample Magnetometer Head?
jmariano
Dear all,
We are in need of a vibrating sample magnetometer for our lab. but don´t have the money to buy a new one.
We are considering
- buy a secondhand one (still expensive)
- buy the VSM head and adapt to a existing magnet. If you now where to find one, I would be happy to hear from you.
- make our own head. If someone has any good suggestions on how to make a good quality vibrator, besides the obvious loudspeaker, I would appreciate if you share your thoughts.
Nay other suggestions are very much welcome.
Tanks
José Mariano
Physics Dep.
University of Algarve
Portugal
Buying the head and adapting a magnet sounds like a good idea to me. The naked magnet should not be too expensive, but you also need a power supply.
I have seen welding power supplies fitted with some means of current control as cheap power supplies for conventional electromagnets.
Because of the power involved the magnet itself has to be water cooled. If you try this, make sure that the power supply is interlocked to the cooling water flow rate. Otherwise you risk boiling the remaining water and causing serious damage (and potential injury).
BTW, that particular magnet was not used for a VSM, so I cannot tell you if the stability is sufficient for such an application.
Actually, we do have the magnet and the power supply, from an old Bruker EPR. Our problem is with the head. I don´t have any idea were we could by one. Probably we have to make one yourself, but I'm not keen on the idea. Bad mechanics will compromise the performance of the device.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
