Help solving the vibrating pole mystery.
A street pole in Italy has been reported to vibrate for extended periods without a clear cause, prompting various theories. Possible explanations include nearby construction, wind turbulence known as "vortex shedding," and resonance effects. Some suggest that traffic could contribute to the vibrations, while others propose testing the pole's response to added weight to confirm resonance. There are speculations about underground machinery, like a water pump, potentially causing the vibrations. Overall, the discussion highlights the mystery surrounding the pole's behavior, with no definitive solution currently available.
Quinzio
The online edition of an italian newspaper, reported the curious event of a street pole which seems to vibrate for prolonged times, hours, even an entire day and without any clear reason.
Someone talks about a building site in the nearby area, other talks about a wind turbulence called "vortex shredding", but the pole has been vibrating, it seems, even is absence of wind.
See the pole in the linked video:
http://video.repubblica.it/edizione...a-e-vortex-shedding/124054/122541?ref=HRESS-6
Looks like it could be from a combination of wind and all the traffic.
The should build all street lamps like this, and harvest the energy to power the lamps.
Looks like a simple case of resonance to me. This hypothesis could be easily tested by sticking a weight to the pole and seeing is it stops.
I wonder if there could be a motor running, underground near the bottom. A water pump, for instance, at just the right frequency could be supplying the energy to make it vibrate.
I think mrpeedybob is right. Load it and see if it still resonates at a few % different frequency. One thing is sure and that is that there is no free energy getting to it.
There is probably no way of testing any hypothesis about it so we should really let it go - PF policy.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
