Method of Undertermined Coefficients
  • Context: Undergrad
  • Thread starter Thread starter tolove
    Coefficients Method
The discussion revolves around the method of undetermined coefficients in solving differential equations, particularly focusing on how to determine the appropriate form of the particular solution, Y(t), for equations involving trigonometric functions. Participants explore the nuances of guessing the correct form based on the characteristics of the equations presented.
  • One participant questions the process of determining Y(t) for trigonometric parts, expressing frustration over the guessing method and its time-consuming nature.
  • Another participant suggests that while guessing is necessary, it should be an informed guess based on the form of the functions involved, emphasizing the importance of matching the overall function types.
  • There is a discussion about the necessity of including terms like At sin(t) or At cos(t) based on the derivatives taken and the presence of trigonometric functions in the homogeneous solution.
  • Some participants argue that the number of derivatives and the coefficients can influence whether to include additional terms like t in the solution.
  • A later reply introduces the annihilator method as an alternative approach, suggesting a more systematic way to find particular solutions.
  • Participants share differing views on whether to always include both sine and cosine terms in the guess, with some advocating for a more cautious approach based on existing roots in the homogeneous solution.
  • One participant reflects on the learning process, noting that the guess-and-check aspect of the method helps build intuition for solving differential equations.
Participants express a range of views on the method of undetermined coefficients, with no clear consensus on the best approach to take when determining the form of Y(t). Some agree on the importance of informed guessing, while others highlight the complexity and variability of the conditions that influence the choice of terms.
Limitations in the discussion include the lack of a definitive pattern for determining when to include additional terms in Y(t) and the dependence on the specific characteristics of each differential equation. The discussion also reflects varying levels of familiarity with the method and its application.
tolove
y(4) - y = 3t + cos t
y''' - y' = 2sint
y(4) + 2y'' + y = 3 + cos 2t
For problems like these, how do you determine what to make Y(t) for the trigonometric part?
Sometimes its At cos t, A cos t, A sin t, and I think occassionally even A0sin t + Acos t
Am I simply supposed to guess until I get the right answer? That's what I'm doing, and it's working, but it feels wrong and is very time consuming.
Thanks!
You are supposed to guess to some extent, but it should be a VERY good guess (or in other words...there is a method to this madness that should get you the right guess almost every time).
to keep it simple, your Y(t) should take on a similar form in terms of its functions. So what I mean is, ignore constants and stuff like that, but make sure your Y(t) has the same overall functions, such as cos(x), sin(x), t, t^2, te^t...etc.
Also, for the part you mentioned you have to occassionally do, once again resort to the logic I just stated. If you have two functions its most often best to split up your function into two functions, BOTH WITH DIFFERENT CONSTANTS. Its a very popular mistake to have...say
Y(t) = A(sint +t)...instead of
Y(t) = Asint +Bt
Also from your previous post I just wanted to make sure that you knew that you don't just "discard" a solution. That imaginary solution you obtained was no solution at all...I checked and it did not satisfy the initial equation. It is simply not a solution, rather than a solution you just discard.
Y(t) = Asint +Bt
Gotcha for most of it, but I can't find a pattern with the trig. Here's the part that's getting me. Look at these two equations:
y(4) - y = cos t
y''' - y' = 2sint
Y(t) for the first one is A t sin t
Y(t) for the second one is just A cos t
It seems like whether or not to add a t depends on the number of times the derivative of the function will be taken and the signs. I don't see any pattern in it as of yet.
Well I think it does have to do with the number of times you differentiate in a way, but in other cases it could depend on your coefficients (sorry I know I previously told you to forget about coefficients, but in some rarer cases such as this one it can come up).
Think about the top equation you gave. If you take the derivative of Acos(t) four times you will end up Acos(t) back. Since you defined your y(t) = Acos(t), the resulting equation will be
Acos(t) - Acos(t) = 0 = cos(t)
This can't be right. So in this case, you would be prompted to use a different form than what lies on the right hand side. In the second equation, clearly we get a more favorable answer. If y = Acos(t), take the derivatives to get
Asin(t) + Asin(t) = 2Asin(t) = 2sin(t)
Obviously we can find A and find a solution for this one. Its also important to note that the right hand side was a 2sin(t) whereas we chose y = Acos(t) and not Asin(t). THIS is because of the number of derivatives. An odd amount on the left will give you the opposite trig function, so this is a clue you can use for determining which trig function. For adding the t, it's a matter of looking at the coefficients and seeing if they will cancel out in the end or not. If they cancel out, you know you CANNOT have a solution of that form. Thus, that is why you add a t.
y(4) - y = cos t
y''' - y' = 2sint
Well, the associated homogeneous equation is y(4)- y= 0 which has characteristic equation [itex]r^4- 1= (r^2- 1)(r^2+ 1)= (r- 1)(r+ 1)(r- i)(r+ i)= 0[/itex]. Of course, that has roots 1, -1, i, and -i and so the general solution to the homogenous differential equation is [itex]Ae^t+ Be^{-t}+ Ccos(t)+ D sin(t)[/itex]. The fact that cos(x) and sin(x) are already in that tells you that you may need t sin(t) and t cos(t). The fact that you don't need [itex]t cos(t)[/itex] is much more subtle (and I am assuming that you are correct that only "At sin(t)" is needed). Personally, I would have used [itex]At cos(t)+ Bt sin(t)[/itex] and then found that A= 0.
Here, the associated homogeneous equation is [itex]y'''- y'= 0[/itex] which has characteristic equation [iex]r^3- r= (r^2- 1)r= (r- 1)(r+ 1)r= 0[/itex]. That has roots r= 1, r= -1, and r= 0 so the general solution to the homogenous equation is [itex]Ae^t+ Be^{-t}+ C[/itex]. Since that involves neither sin(t) nor cos(t), we don't need the extra "t". Again, I would use [itex]A cos(t)+ B sin(t)[/itex] myself.
Method of undetermined coefficients is a silly version ofthe annihilator method.
The idea is we have an equation
P(D)y=f
where P(D) is the differential operator
where f is a solution of
Q(D)f=0
so we solve
Q(D)P(D)Y=0
then check
P(D)Y=f
to find the particular solution
we write
Y=Yparticular+Yhomogeneous
where
P(D)Yparticular=f
and
Yhomogeneous is the general solution of
P(D)Y=0
as state above sometimes we know in advance that a coefficient is zero and can omit it.
Ooo, this makes a ton of sense.
What you're saying is to always choose A0sint + Acost, unless it's painfully obvious which one I can leave out. If only one is needed, the A0 or A will turn out to be zero as is appropriate.
If a trigonometric root already exists, then use:
tn(A0sint + Acost), with n being one higher than the already existing root.
Actually yes. :)
There are rules that people have pointed out and you are learning. However, an important step in learning how to solve differential equations is developing intuition into how a solution behaves. This is especially true when dealing with real world ODE's and PDE's. IMO the guess and check part of the method of undetermined coefficients helps greatly in building the intuition.
It is worth pointing out that there are methods developed that will allow you to directly calculate a particular solution. For example you can use variation of parameters or Laplace transforms. However these generalized methods are more time consuming, and can involve ugly integrals. Being able to guess the form of a particular solution will save you a ton of time and effort in the long run.
I don't think undetermined coefficients (I refer to this case not in general) builds very much intuition as if you understand what is happening, you know what to "guess". I think some other thing build intuition like drawing slope fields, iterative methods, numerical methods, and asymptotic methods. I hate the way things like long division, factorizing, and undetermined coefficients are often presented as guessing without explaining the reasoning.
  • · Replies 36 ·
