Question about steam pressure and velocity
The discussion revolves around the issue of steam pressure and velocity in a natural gas fueled boiler system, specifically focusing on the damage observed in a heat exchanger over time. Participants explore the relationship between steam velocity, pressure, and potential causes of wear or damage to the heat exchanger.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions whether the velocity of steam contributes to the damage observed in the heat exchanger, suggesting that the size of the boiler and pipe may lead to higher steam velocity.
  • Another participant argues that the BTU rating of the boiler does not significantly affect the pressure or velocity of the steam, proposing that corrosion might be the actual cause of the damage.
  • A different participant suggests that erosion could be a factor and inquires about the specific location of the hole in the heat exchanger, speculating about the design of the heat exchanger.
  • There is a reminder to avoid double-posting, indicating some level of moderation in the discussion.
Participants express differing views on the cause of the damage to the heat exchanger, with some attributing it to steam velocity and others suggesting corrosion or erosion. The discussion remains unresolved regarding the primary cause of the issue.
Participants have not reached a consensus on the relationship between steam velocity, pressure, and the observed damage, and there are assumptions about the design of the heat exchanger that remain unverified.
RHorseUSMC
I am trying to figure out a problem we are having with a steam boiler. First, it is a natural gas fueled boiler rated at 2,000,000 BTU. In the summer time, the boiler supplies heat to the indoor pool through a heat exchanger. There is approximately 10 ft of 1 inch black iron pipe feeding into the top of of the copper heat exchanger. The problem is that over a 2-year period the steam coming into the heat exchanger @ 40 psi has cut a hole into the heat exchanger. My question is does velocity have any part in this? Someone had told me that do to the size of the boiler (2,000,000 BTU) and the size of the pipe feeding the heat exchanger, the velocity of the of the steam is higher and therefore creating a hole in the heat exchanger. Is there a formula to figure this or can anyone just explain it to me. Thank you--Rick
No, the BTU rating has very little to do with the pressure/velocity of the steam in the system (ie, a vastly oversized boiler would simply fire less often and produce roughly the same pressure/velocity). What you have there is probably due to corrosion.
Where is the hole, exactly? I'm pretty sure that copper and steel are the metals that don't work-and-play-well-with-others in plumbing. Ie, if you put them near each other without a dielectric fitting to separate them, they will create a galvanic cell and quickly dissolve the steel.
It could very well be an erosion issue. Usually a heat exchanger won't be made entirely out of copper, just the core. Where exactly is the hole in the heat exchanger? Does it happen at a 90° bend? I am imagining a shell and tube heat exchanger. Is this correct?
  • · Replies 24 ·
