What is the significance of string theory in understanding the universe?
Crazy Moron
So, what is it?
Math assumes non-dimensional points on a number line are separated.
But assumes the points have no distance between them.
If a point has 0 length on a number line, and it is 0 distance from the point beside it, they are the same point. You cannot create a number line with points that have no length and no distance between them.
String theory assumes points have a length on a number line, or that the points are separated by a distance. A distance on a number line is 1 / divided by a number.
Points are only not separate from each other when their size and the distance between them is 1/infinity. Infinities don’t exist in math, so while math incorrectly assumes points with no size can sit directly next to each other, math cannot include an exact idea of infinity.
1/9,000,000,000,000,000, or however many zeroes you want to add is math, so the closest that math can get to dividing down to zero distance and a zero-sized point on a number line is a very small distance and a very short point. In other words, a string.
That is what string theory is.
Given that concept for string theory, now it’s possible to answer a few other interesting questions.
If points are small distances, then the distances can vary, which gives us a space that can stretch, warp, and curve. Now, using that concept of string theory, we can describe a continuum that can change shape, exactly like it is supposed to in Special Relativity.
Einstein began to think in 1936 that there cannot be a continuum, and by 1956 he had privately concluded a continuum is impossible and all of his ideas about gravity are invalid. That incorrect conclusion may be because he correctly realized points cannot have no size and no distance between them, and create the continuum he needed.
-John Cauthen
not understood properly
i wanted to ask, something like this whether the continuum concept has its origin from the physiacl existence or from mathematics of pure numbers, so i wanted to ask how its related to the concept of continuum (i know both ae same , but) in mechanics where we satte like one-one mapping between a material body and and space where it totally fits into that , so is there any thing some kind of proof which tell us that , there exists contoinuum eventhough it has been hypothised . If it exists then how far the matter behaves from the existing continuum .
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
