Is it Possible to Travel Faster than the Speed of Light?
The discussion revolves around the possibility of traveling faster than the speed of light, using a hypothetical scenario involving two observers moving towards a speed limit sign at 0.75 times the speed of light. Participants explore the implications of relative velocities and the measurements involved in such a scenario.
  • One participant describes a scenario where they and their brother are both traveling towards a sign at 0.75c and concludes they are closing the distance at 1.5c, raising questions about how this could be possible.
  • Another participant challenges the assertion that the distance is reducing at a rate that implies speeds greater than light, emphasizing that velocity addition is not linear.
  • Several participants provide calculations using the relativistic velocity addition formula, showing that the relative speed would be approximately 0.96c, not 1.5c.
  • There is a contention regarding the validity of the initial assumptions made about relative speeds and the implications of those assumptions on the conclusions drawn.
  • Some participants argue that the scenario presented is flawed and cannot logically lead to the conclusion of exceeding the speed of light.
  • One participant expresses uncertainty about their understanding and suggests the need for clearer numerical details to support the argument.
Participants do not reach a consensus. There are multiple competing views regarding the interpretation of the scenario and the application of relativistic principles, with some asserting that the initial assumptions are incorrect while others maintain their perspective.
Participants highlight the importance of considering the frame of reference when discussing relative velocities and caution against mixing measurements from different frames. There is an acknowledgment of the complexity involved in relativistic physics that may not be fully addressed in the initial scenario.
  • #61
To put it simply (I hope)
We measure 2Ls of distance.
1.333 secs later, we measure 0 distance.
How is that possible?
  • #62
James S Saint said:
No it is according to US.
Who is "US"? You? Your brother? The ground? All three frames will measure different distances and times.
You say "US", but you are actually using ground frame measurements.
We measure 2Ls of distance. In merely 1.333 secs, we measure NO distance between us. How is that not 1.5c?
It is 1.5c, but only in the ground frame. You used distances and times in the ground frame, so the closing speed is in the ground frame.
  • #63
Bussani said:
Like Doc Al's pointed out, relativity doesn't forbid the distance between the two ships from receding at a faster than light rate according to a ground observer. That's nothing special.
Side question, if I may ask: who would reach the sign first according to all 3 observers ("you" in the vehicle, your brother in the oncoming vehicle, and a person standing beside the sign)? I assume if the person by the sign sees them reach it simultaneously, the other two won't agree with him.
They would all agree on the simultaneity of the intersection. If they don't steer carefully they could headon and then it would be obvious they met simultaneously. Seriously though, all observers agree on local events at a single location. SImultaneity becomes relevant when events are separated spatially
  • #64
Where's the problem?
You are confusing a closing speed greater than c with something actually moving with a speed greater than c in some reference frame. But that's not the case.
  • #65
HallsofIvy said:
Wow, 57 posts in less than 3 hours! That may be a record. James S Saint, you are doing all of your computations as if Newtonian physics applied. Naturally, you are going to get a contradiction to relativity.
Actually I'm tickled to find a forum where people are so active.
Now if I can just get them to follow logic... grin. :)
  • #66
Becaus we're measuring the distance and time in the ground observers frame, where both of you are moving. Simples.
Imagine a 100m race. If someone runs 100m in 10 secs (assuming constant speed), but the finsihing linen approaches them at the same speed, do we say they ran 100 m in 5 secs? No we don't bceause we're talking about the frame in which both the runner and the finsihing line are moving,therefore the runner ran 50m in 5 secs.
  • #67
jcsd said:
Is the light therefore traveling at greater than 1.5 times the speed of light? That would be totally illogical as we started by assuming it travels at the speed of light.
Also, what about someone standing at the one second mark and in the signpost's reference frame. If your brother shines a light back at that observer after he passes, will that observer see light traveling at 1/4 the speed of light? No.
  • #68
You abuse the term 'logic'. What you really are saying: "If I can just get them to agree with me." But many of your statements are incorrect!
It's not a problem with 'logic', but with your understanding of physics.
  • #69
The "problem" is that speed is ONLY measured by distance and time, agreed?
We (my brother and I - the only people involved) measured 2Ls of distance between us. It doesn't matter where we were. It doesn't matter if there was a ground. We could have simply met in space and slowly backed away to a distance of 2Ls. No distortions involved.
But 1.333 secs later, we are back where we started.
The "problem" is that we are measuring speed by time and distance which tells us that one of us traveled at 1.5c. We can't really know which one of us. But SOMETHING happened faster than light.
  • #70
Trust me for a moment. You do NOT want to lecture me about what logic is or isn't. I am letting that go as it is a different thread topic.
  • #71
:rolleyes:
  • #72
I'm still waiting on your explaiination of how fast light travels when it is coming from your brother's ship. I would love to hear how light travels faster than light.
  • #73
Of course. But what you don't seem to be getting is that distance and time are with respect to some reference frame.
Sorry, still wrong. A distance of 2 Ls implies some reference frame. In this case, the ground frame.
Again, only with respect to that ground frame.
Nonsense. All it tells you is that with respect to the ground frame, the distances closed at a rate of 1.5c.
  • #74
I am trying desperately to keep this as simple as possible. The issue of how fast light might be going here or there is not really the issue.
Now i have even removed the ground from the scenario to simplify further. Someone please just answer this;
  • #75
Borek said:
Assuming that just because one of them moves at 0.75c means the other can get faster than 0.25c seems wrong to me. Following this line of thinking, what happens to the light emitted by our Sun? If it goes in the direction of the Earth with c, everything emitted in the opposite direction has to stop?
espen180 said:
As for the light question, a photon doesn't have an intertial reference frame, you we cannot ask what the world looks like for a photon.
I was referring to this statement by DaleSpam:
DaleSpam said:
Here is the problem. You are starting with a flawed premise. In this arrangement the fastest your brother can possibly be closing with the sign is <0.25c.
  • #76
Sorry, it's not as simple as you envision. Please answer the question. How fast do you (in your ship) think that the light from your brother's flashlight travels?
  • #77
We didn't even know there was a ground. We saw, measured 2Ls. Yet 1.333 secs later, we BOTH saw 0 distance.
From our perspective, we would not be able to know who "traveled", but only that one of us obviously did. And that one got to the other at 1.5c.
  • #78
The issue with the light beam was just used to point out the logical consequence of your statements and how they contradict what we know about how light works. There's logic coming to bite you in the butt again!
It's been answered several times.
  • #79
You cannot remove the ground frame, because that's where you are making for measurements, whether you realize it or not.
In your ship's rest frame the time from start to meetup is approx 0.9 seconds, and your brother is approx 0.2 light seconds away from the signpost when the race starts. You are approx 0.66 light seconds away from the same signpost.
  • #80
Measured 2 Ls according to what frame? 1.333 s according to whom?
You are stuck in your pre-relativistic notions that distance and time are independent of the frame doing the measurements. Physics has moved beyond that!
Again, only as measured with respect to the ground frame.
You don't seem to be interested in learning about relativity, so this thread is going nowhere fast.
  • #81
James S Saint said:
Yes, but I'm not talking about what a ground observer sees. I see the distance of 2Ls get reduced to 0 in only 1.333 secs. That is what matters. Perhaps I cannot actually see the ground at all or even know it exists. As stated just prior, the ground only serves as an equal frame for us to begin and end. Both of us would end up seeing that 2Ls of distance vanished in only 1.333 secs.
That's where people start telling you you're wrong. What you're not getting is that you're using distances measured in one frame of reference and then telling us to ignore that frame of reference. It doesn't matter if there's ground or not. The closing speed is only 1.5c according to the measurements made in that frame. That's allowed and isn't anything special--there's nothing in relativity that forbids that. If you're saying, "Ignore what you see in the ship and just go from what you know from before the experiment," then you're working from the "ground frame", whether you like it or not.
Hm, I guess that makes sense. Thanks.
  • #82
Let's see what we CAN agree to. Assuming the floating in space modification to the original OP;
Does anyone disagree with that post?
  • #83
Yes. See Post #79, where I have calculated the actual measurements you would make.
  • #84
Of course we disagree with it! Where have you been?
  • #85
So everyone agrees that we both measured 2Ls and within 1.333 secs, we both measured 0?
A) Now the whole point to relativity is that there is no actual absolute frame, thus neither brother can claim to be the one traveling. All we see is 2Ls of distance vanish in 1.333 secs.
B) We have no means to use the equation involved, because we do not know where ground would be. We do not know who was traveling. ALL we know is that within 1.333 secs, what was 2Ls disappeared.
C) From ALL we know, one of us traveled at 1.5c.
Now which of A,B, and C is disagreeable?
  • #86
Still waiting...
  • #87
Ok, what part of THAT post do you disagree with?
  • #88
Borg said:
Still waiting...
One traincrash at a time, please. I'll get to it if I can get anywhere with what I am pursuing first.
Do you disagree with that post in question and if so with what part?
  • #89
Yes, I completely disagree with your post(s). My question was made to get you to realize the illogic of your assumptions. If you answer the question, you might see that there are problems with your assumptions.
  • #90
:smile:
All of them are wrong. Assuming instant acceleration, the actual situation, in either of the ships' rest frames, is 0.86Ls being traversed in 0.9 secs.
  • · Replies 93 ·
  • · Replies 26 ·
  • · Replies 51 ·
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 40 ·
