Did I Apply the Derivative Rule Incorrectly for x²?
  • Context: High School
  • Thread starter Thread starter Suraj M
    Derivative
The discussion centers on the application of the derivative rule for the function x². The original poster incorrectly equated the derivative of x² to x by misapplying the sum of terms approach. The correct derivative, as established, is d/dx(x²) = 2x, derived using the product rule. The confusion arose from treating x as a constant in the expression d/dx(x + x + ... + x) x times, which led to an incorrect conclusion.
  • Understanding of basic calculus concepts, specifically derivatives.
  • Familiarity with the product rule in differentiation.
  • Knowledge of limits and their role in defining derivatives.
  • Ability to manipulate algebraic expressions involving variables.
  • Study the product rule for differentiation in depth.
  • Learn about the limit definition of derivatives, specifically for polynomial functions.
  • Explore common pitfalls in applying derivative rules, particularly with variable limits.
  • Investigate the implications of treating variables as constants in calculus.
Students beginning their journey in calculus, educators teaching differentiation, and anyone seeking to clarify common misconceptions in derivative applications.
Suraj M
i just started with calculus. There was this question my teacher asked us
d/dx (x²) = 2x ... eq 1
now we can write 2² = (2+2)
3² = (3+3+3)
4²=(4+4+4+4)
n² = (n+n+n+n+...)n times
so here d/dx (x²) = d/dx (x+x+x+...)x times
so ⇒ d/dx (x) +d/dx(x) +...(x times) = 1+1+1+...(x times) = x
⇒d/dx (x²) = x
where did I go wrong??
3² = (3+3+3)
4²=(4+4+4+4)
⇒d/dx (x²) = x
When you wrote 2² = (2+2). 2² = (2*2)
i never said that! Did I?
You said this in your original post (OP):
Which I corrected to 2*2...
But it's also true that 22 = 2 + 2, and that 32 = 3 + 3 + 3
Oh, huh. Yeah, I guess it is. Okay, never mind...
It's true that 22 = 2 + 2, and 32 = 3 + 3 + 3, but what do you do with an expression such as 1.12? Can you have 1.1 terms being added together? That makes no sense.
The right way to do this is to recognize that x2 = x * x. Now d/dx(x2) = 2x, and d/dx(x * x) = x * 1 + 1 * x = 2x, using the product rule in differentiating.
3² = (3+3+3)
4²=(4+4+4+4)
⇒d/dx (x²) = x
d/dx (x+x+x+...)x times needs to take into account x times, which you did not.
By definition of derivative, we have
$$\frac{d}{dx}x^2 =\lim_{h\to 0}\frac{(x+h)^2-x^2}{h}.$$ That ##x## may be an integer, but the value of the expression on the right is completely determined by the values of ##\frac{(x+h)^2-x^2}{h}## for non-zero values of ##h## in the interval ##(-1,1)## (or any other open interval that contains ##0##). So for all relevant values of ##h##, the sum ##x+h## isn't an integer.
My first thought was that he did, by writing ##1+1+\cdots+1=x##. But you're right. We're differentiating with respect to x, so we can't treat any x in the expression as a constant.
\begin{align}
&\frac{d}{dx}x^2 =\lim_{h\to 0}\frac{ (x+h+x+h+\cdots)_{x+h\text{ times}}-(x+x+\cdots)_{x\text{ times}}}{h} =\lim_{h\to 0}\frac{(x+x+\cdots)_{h\text{ times}}+(h+h+\cdots)_{x+h\text{ times}}}{h}\\
&\lim_{h\to 0}\frac{hx+(x+h)h}{h} = x+\lim_{h\to 0}(x+h)= x+x=2x.
\end{align}
Edit: I should add that this calculation doesn't really make sense. Specifically, the notations "x+h times" and "h times" don't make sense, since h isn't an integer. This calculation is at best a reason to suspect that ##\frac{d}{dx}x^2=2x##.
Thank you , all for those replies, thank you Fredrick for that first principle method, by my question still stands,I understand that by first principle and using x²=(x+x+x+...+x)x times we still get 2x but then why not by the common method of directly applying the operator. Is there some rule I'm violating?
PS. I'm sorry if you already mentioned it and i missed it!
The main problem was identified by mathman. You didn't correctly account for the last x in ##(x+x+\cdots)_{x\text{ times}}##. In other words, what you did isn't equivalent to defining f by ##f(x)=(x+x+\cdots)_{x\text{ times}}## and then computing ##f'(x)##. It's equivalent to defining ##f(x,y)=(x+x+\cdots)_{y\text{ times}}## and then computing the partial derivative ##D_1f(x,x)##.
oh ok i understood.! Thank you all.
$$\frac{d}{dx}x^2 =\lim_{h\to 0}\frac{(x+h)^2-x^2}{h}.$$ That ##x## may be an integer, but the value of the expression on the right is completely determined by the values of ##\frac{(x+h)^2-x^2}{h}## for non-zero values of ##h## in the interval ##(-1,1)## (or any other open interval that contains ##0##). So for all relevant values of ##h##, the sum ##x+h## isn't an integer.My first thought was that he did, by writing ##1+1+\cdots+1=x##. But you're right. We're differentiating with respect to x, so we can't treat any x in the expression as a constant.
\begin{align}
\end{align}
Is there a way to find
\begin{align}
\frac{d}{dx} \sum_{1}^{x} f(x)
\end{align}
without calculating the sum explicitly ?
\begin{align}
\end{align}
You'd have to define the notation before you can start thinking about how to find the number it represents.
I realized that shortly after I made my post.
Surely one cannot differentiate factorials ? They have values only when ## x ## is an integer, continuous does not even make sense there when you try to plot it.
However, one can extend the definition of factorials to the gamma function, which one can actually differentiate.
I suppose for my question to make sense, I have to first ask whether there is a way to extend the definition of summation to non-integer values of ##x## ?
Then my question becomes whether one can apply some sort of a chain rule so that one can evaluate the derivative of the extended summation without needing to evaluate the summation first.
If I understood the OP's question correctly, he has the following:
\begin{align}
\sum_{k=1}^{x} x = x^2
\end{align}
But when he tries to calculate the derivatives of both sides, he doesn't get matching answers. I presume that is because there is some hidden chain rule which he is not applying ?
My guess would be that when he differentiates ## (x+x+x+...)_x ##, he has to apply the chain rule this way:
\begin{align}
\frac{d}{dx} (x+x+x+...)_x = (\frac{d}{dx}[x+x+x+...] )_x + (x+x+x+...)_\frac{d(x)}{dx}
\end{align}
\begin{align}
&= (1+1+1+...)_x + (x+x+x+...)_1
\end{align}
\begin{align}
&= x + x
\end{align}
\begin{align}
&=2x
\end{align}
Is that correct ?
\begin{align}
\end{align}
\begin{align}
What did you do here Montadhar?
I didn't understand the way you applied the operator (d/dx)..
Is this some other rule, that I'm not aware of??
in "so here d/dx (x²) = d/dx (x+x+x+...)x times" there is no guarantee that x is an integer, so "x times" is ill defined.
Do you mean why did I differentiate the 'x-times' in this expression ?
\begin{align}
\end{align}
mathman and Fredrik said earlier that you differentiated as if the 'x-times' was a constant, which is why you got the wrong result.
So I was trying to come up with a way that does not use 'x-times' as a constant, but takes it into account too when you differentiate. So I used some kind of a product rule as a guess, and it turns out that it gave the right answer in this case.
  • · Replies 30 ·
