2 Block and a pulley(has mass) system
The discussion revolves around a physics problem involving a block and a pulley system with mass. The key equations utilized include the conservation of energy and Newton's second law. The analysis reveals that while increasing the radius of the pulley increases its inertia, the acceleration of the block is independent of the radius and inversely proportional to the mass of the pulley. Consequently, a decrease in the mass of the pulley results in increased acceleration, leading to the block falling faster than initially expected.
  • Understanding of conservation of energy principles
  • Familiarity with Newton's second law of motion
  • Knowledge of torque and rotational dynamics
  • Ability to analyze free body diagrams
  • Study the effects of pulley mass on acceleration in mechanical systems
  • Learn about the relationship between inertia and angular acceleration
  • Explore advanced applications of Newton's second law in multi-body systems
  • Investigate conservation of energy in rotational systems
Physics students, educators, and anyone interested in understanding the dynamics of block and pulley systems in mechanics.
okgo
http://i43.tinypic.com/352nlw2.jpg
I need help with the question 25. The three star (hardest) problem.
well conservation of energy is
Mgh=.5Mv^2+.5Mv^2+.5(.5MR^2) ω^2
Wouldn't increasing the Radius increase the Inertia by a factor of 4 and decreasing the mass reduce it only by a factor of 2. So the velocity should be less due to the increased inertia and the block would fall slower.
Anyone have any idea why the block would fall faster than the original?
Since the single string is connecting the two masses, the acceleration of masses anfd the pulley must be the same. Let T1 be the tension in the horizontal segment of the string and T2 be the tension is the vertical segment of the string. Now draw the free body diagram. Applying Newton's second law, you have
T1 = ma ...(1)
Net torque τ = (T2 - T1)*R = I*α = 1/2*M*R^2*α. R*α = a. So
T2 - T1 = 1/2*M*a...(2)
mg - T2 = ma...(3)
From these equations find the expression for the acceleration a.
You can see that acceleration is independent of the radius of the pulley and it depends on the mass of the pulley.
In the acceleration expression the mass of the pulley appears in the denominator. So as mass decreases the acceleration increases.
  • · Replies 30 ·
