Complex Integration: Contour Evaluation and Estimation Lemma
The discussion focuses on evaluating the contour integral ∫C Im(z − i)dz, where C consists of a circular arc and a line segment. Participants suggest using the parameterization z = x + iy and converting the integral into terms of t for easier calculation. For the second question regarding the circle |z| = 4, it is recommended to apply the estimation lemma to show the inequality involving the integral of ez/(z+1). The conversation emphasizes the importance of proper parameterization and substitution in contour integration. Overall, the thread provides insights into solving complex integrals using contour evaluation techniques.
nickolas2730
1.Evaluate ∫C Im(z − i)dz, where C is the contour consisting of the circular arc along |z| = 1 from z = 1 to z = i and the line segment from z = i to z = −1.
2. Suppose that C is the circle |z| = 4 traversed once. Show that
§C (ez/(z+1)) dz ≤ 8∏e4/3
For question 1, should i let z= x+yi to solve the question?
and it said the I am part so i just need to consider the "yi"?
i tried but really have no idea on these 2 questions..
Please help
Thanks
Yes, let z=x+iy and then integrate iy-i over z=e^(it) as t goes from 0 to pi/2. So wouldn't that be:
\int_0^{\pi/2} Im(z-i)dz,\quad z=e^{it}
You can convert that to all in t right? dz=ie^(it)dt=i(cos(t)+isin(t))dt and won't y be just sin(t)?
For the contour from i to -1, need to do that one in terms of z=x(t)+iy(t). Isn't that line just y=x+1 as x goes from 0 to -1? So suppose I let x=x(t)=t, then y(t) is? Now substitute all that into the integral:
\int_0^{-1} (iy-i)dz,\quad z=x(t)+iy(t)
with dz=x'(t)+iy'(t)
For the second one, use the http://en.wikipedia.org/wiki/Estimation_lemma" .
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
