2 multivariable limit questions.
  • Thread starter Thread starter AndreTheGiant
    Limit Multivariable
13 replies · 2K views
AndreTheGiant
Hello, I need help on the following questions, mainly to make sure i did them right.
for both, lim (x,y) -> (0,0)
1) [PLAIN]http://www4d.wolframalpha.com/Calculate/MSP/MSP3619hd2e84h398acc80000110c0eac25d415ha?MSPStoreType=image/gif&s=57&w=72&h=44
2) [PLAIN]http://www4d.wolframalpha.com/Calculate/MSP/MSP43819hd2e19gfb031c4000051d54bgf834ga83b?MSPStoreType=image/gif&s=47&w=80&h=40
1) so for this one I multiplied by the conjugate of the denominator.
So what i end up with is as follows
x(x-y)(sqrt x + sqrt y) / (x-y)
x-y cancels so I am left with
x(sqrt x + sqrt y)
so I get the limit as 0 when i plug in x and y.
2)
This one I am clueless about what to do. I keep getting an indeterminate form 0/0. I tried L'hopital's rule but it doesn't really help. Any ideas? Do i need to use some trigonometric identity here?
(1) This is correct.
(2) Try approaching (0, 0) along some line which passes through the origin.
Alternatively, you can see what limit you get if you approach the x-axis along the line x = b, for some constant, b ≠ 0. Then, if that limit exists, approach (0,0) with that expression. Do similar for the y-axis.
Thanks for the reply.
I'm still a bit lost on #2. Using the first method such as taking a curve, say y=x that passes through the origin i still end up with 0/0, i tried l'hospital's rule after using y=x for example and I still don't get anywhere.
as for taking some x=b, so suppose b=1, then I would lim x,y -> 1,0. which also gives me an indeterminate form 0/0?
Sorry bout that. This is the question.
lim
x,y -> 0,0
[cos(xy)-1]/[(x^2)(y^2)]
Hmm looks like there is an error somewhere in the latex code, can't see what is written, but I'll try subbing in mx like you said and see what I can do from there with l'hospital's. I might have done something wrong then.
Using l'hospital's will make me get rid of the x from the denominator eventually but i think it will take more than 2 times. This is what i have so far.
using l'hospital's the first time I got:
-2mx sin(mx^2) /( 4x^3)(m^2)
which is still 0/0 as x -> 0
second time:
[-2m sin(mx^2) - 4m^2x^2 cos(mx^2)]/](12x^2)(m^2)]
which is still 0/0
unless i did something wrong, i can keep using l'hospital's to remove x from the denominator and should not give me 0/0 but it will be a total of 4 times I have to use it.
Cancel what you can before proceeding.
...right! stupid mistakes :(
thanks so much for the help!
