Manipulating Equations for Perpendicular Oscillations
The discussion centers on deriving the trajectory equation for two perpendicular oscillations represented by the equations \(x=A\cos\omega t\) and \(y=B\cos(\omega t+\Delta\phi)\). The user initially manipulates the equations to arrive at an intermediate form, but struggles to transition from equation (2) to the desired equation (3). Key insights include the importance of correctly applying trigonometric identities and recognizing the limitations of using square roots in transformations. Ultimately, the user successfully derives the final equation after receiving guidance on factoring and manipulation techniques.
  • Understanding of trigonometric functions and identities
  • Familiarity with algebraic manipulation techniques
  • Knowledge of parametric equations and their transformations
  • Basic understanding of oscillatory motion in physics
  • Study the derivation of parametric equations for oscillatory motion
  • Learn about trigonometric identities and their applications in algebra
  • Explore methods for solving systems of equations involving trigonometric functions
  • Investigate the implications of using square roots in trigonometric transformations
Students studying physics or mathematics, particularly those focusing on oscillatory motion and trigonometric identities, as well as educators seeking to enhance their teaching methods in these areas.
Xsnac
I have 2 perpendicular oscilations and I have to find the trajectory equation.
$$x=A\cos\omega t\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (1)$$
$$y=B\cos(\omega t+\Delta\phi)$$
$$\cos (x+y) =\cos x\cos y -\sin x\sin y$$
$$\cos^{2} x+\sin^{2} x =1$$
and from (1)
$$\cos\omega t =\frac {x}{A}$$
I basicaly spent 2 hours trying to algebraicaly manipulate the equationThe closes I could get was:
$$\frac {y^{2}} {B^{2}} -2\frac {xy} {AB}\cos\Delta\phi + \frac {x^{2}} {A^{2}}\cos^{2}\Delta\phi = (1 - \frac{x^{2}} {A^{2}} )sin^{2}\Delta\phi\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (2)$$
The end result should be:
$$\frac {x^{2}} {A^{2}} +\frac {y^{2}} {B^{2}}-2\frac {xy} {AB}\cos\Delta\phi=sin^{2}\Delta\phi \,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (3)$$
I have no ideea how to get from (2) to (3). :mad:
Thank you in advance for reading this wall of text.
I'm not sure what you want. You already have parametric trahectory equations: x(t) = stuff; y(t) = other stuff
Do you want a coordinate equation y(x)?
I don't know how to get from (2) to (3). I want to know the steps I have to make to get from (2) to (3)...
$$\cos x+y =\cos x\cos y -\sin x\sin y$$
and from (1)
We need to see the details: what are the steps you took to get to your (2)? Perhaps you made some errors, but we cannot tell until you show us.
For the record: I get the result (3).
BTW: your equation ##\cos x+y =\cos x\cos y -\sin x\sin y## is almost certainly false, as it says ## y + \cos x =\cos x\cos y -\sin x\sin y##, which is untrue for most ##x,y##. However, an equation such as ##\cos (x+y) =\cos x \cos y -\sin x \sin y## is true for all real ##x,y##.
sorry it was a typo ... well the stepps I took are the following
I expanded the cos function of $$y=B\cos(\omega t+\Delta\phi)$$
and replaced all the $$\cos\omega t$$ with $$\frac {x}{A}$$
then I transformed the $$\sin\omega t$$ into $$\sqrt{1 - \frac{x^{2}} {A^{2}}}$$
In the end I divided everything by B and squared everything to get rid of the root.
Transforming ##\sin(\omega t)## into ##\sqrt{1 - \cos^2(\omega t)}## is a mistake, as it eliminates the parts where ##\sin(\omega t) < 0##. The point is that, by definition, ##\sqrt{ \cdot } \geq 0## for any real argument, but sometimes you want to have ##\sin(\omega t) = - \sqrt{1 - \cos^2(\omega t)}##. It is a lot easier to just use ##u = \cos(\omega t), v = \sin(\omega t)## and then express ##x(t), y(t)## in terms of ##u,v##. Of course, ##u^2 + v^2 = 1## for all ##t##.
Ur wrong. I figured it out with a little help from someone else. Had to multiply the right parenthesis with $$\sin^{2} \Delta \phi$$ , move the second term to the left side, factorise out $$ \frac {x^{2}} {A ^{2}} $$ and then the remaining equation is identical to (3)
reminder of what I had
and where I got
and where I got
No, I am NOT WRONG. Writing ##\sin(r) = \sqrt{1 - \cos^2(r)}## can be incorrect, and by definition of the function ##\sqrt{ \cdot }##, it is ##\geq 0## for all real arguments. Those are just plain facts.
These issues have been explained over and over again, many times, in numerous discussions in this forum. I did not make these things up.
Aside from that, whether of not expressing ##x,y## in terms of ##u,v## and then using ##1 = u^2 + v^2## is easier or harder than some other way is largely a matter of opinion; I found it easier.
Ur wrong in the sense that saying what you just said is not getting me closer to solving the problem. But thank you anyway.
  • · Replies 40 ·
