Maximum work during reversible process?
Maximum work is achieved during reversible processes, as demonstrated by comparing two scenarios of ideal gas expansion. In an irreversible process, the work done is greater than in a reversible process, as shown in the examples provided, where the absolute values of work differ significantly. The discussion also highlights the importance of using correct formulas for calculating work and heat absorbed during these processes. Additionally, there is a query regarding the accuracy of solutions to specific problems from NCERT textbooks, particularly concerning the calculations for reversible expansions. The conversation concludes with a question about whether maximum work during compression occurs under reversible or irreversible conditions.
adianadiadi
maximum work during reversible process?
I have seen maximum work is achievable when the process is carried out reversibly. Is it correct?
For example, if you look at the following problems,
1) Ten litres of an ideal gas at a pressure of 10 atm expands isothermally against a constant pressure of 1 atm until its total volume becomes 100 litres.The amount of heat absorbed in the expansion is
The answer is -90 L-atm
(I have used the formula w = -p(ext)*(v2-v1))
2) Ten litres of an ideal gas at a pressure of 10 atm expands isothermally under reversible conditions until the final volume becomes 100 litres.The amount of heat absorbed in the expansion is
The answer is -23.03 L-atm
(Here the formula used is w = -2.303*p(internal)*log v2/v1)
In the first problem, the process is irreversible and the process in second problem is reversible. Here the work done in case of irreversible process is greater than that in reversible process. (Just consider the absolute values and not the negative signs)
Could you please explain this? Am I wrong anywhere?
Hi adianadiadi, welcome to PF. The second answer should be -230 L-atm:
\int -p\,dV=-nRT\int_{V_1}^{V_2} \frac{dV}{V}=-P_1V_1\ln 10=-230
Does this answer your question?
ThanQ very much Mapes! Now I got the answer.
If you have time, could you please tell me whether the solution given to the problem 6.4 is correct or not? I think this is wrong. It should be then, 32.2 L-atm.
These problems are given in NCERT textbooks.
http://www.ncert.nic.in/book_publishing/CLASS 11/Chemistry/Part I/6.pdf
Problem 6.2
Two litres of an ideal gas at a pressure of 10 atm expands isothermally into a vacuum until its total volume is 10 litres.How much heat is absorbed and how much work is done in the expansion ?
Solution
We have q = – w = pex (10 – 2) = 0(8) = 0
No work is done; no heat is absorbed.
Problem 6.3
Consider the same expansion, but this time against a constant external pressure of 1 atm.
Solution
We have q = – w = pex (8) = 8 litre-atm
Problem 6.4
Consider the same expansion, to a final volume of 10 litres conducted reversibly.
Solution
We have q = – w = 2.303 × 10 x log10/2 = 16.1 litre-atm
Thanking you once again.
Looks good, but check 6.4 again.
In 6.4, the value 10 is just the pressure. I think we should also take initial volume 2 lit.
I got another doubt. Whether the work done during compression is maximum under reversible conditions or in irreversible conditions?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
