2nd order inhomo differential eq.
The discussion focuses on solving the second-order inhomogeneous differential equation y'' = t^2. The general solution consists of a complementary solution, y_c = C1 + C2t, and a particular solution, y_p, which is suggested to be of the form At^4. The method of undetermined coefficients is emphasized as the correct approach to find the particular solution, where the user must substitute y_p into the original equation to determine the coefficient A. The importance of correctly applying this method is highlighted to ensure accurate solutions in constant-coefficient linear differential equations.
  • Understanding of second-order differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of complementary and particular solutions
  • Basic calculus, specifically differentiation
  • Study the method of undetermined coefficients in detail
  • Practice solving second-order inhomogeneous differential equations
  • Explore complementary and particular solutions for various forms of differential equations
  • Review examples of linear differential equations with constant coefficients
Students studying differential equations, mathematics educators, and anyone seeking to improve their problem-solving skills in second-order inhomogeneous differential equations.
projection
y'' = t^2
The general solution to the homogenous diff equation is y(t)= C1 + tC2 i beliee. The particular solution is where i am having trouble.
the guess is of the form \alpha t^2 + \beta t + \gamma ... but taking 2 deriatives leads to just 2\alpha = t^2 ... this can only be zero if \alpha = \frac{t^2}{2} but this is something i haven't encountered as the constants are usually numeric values... and what about the rest of constants of beta and gamma?
Try a particular solution of yp = At4.
The general solution will be the complementary solution (c1 + c2t) plus the particular solution.
i am not following... i am trying to find a particular solution... am i not supposed to find a polynomial of similar degree with unknown coefficients and finding derivates and then equating it to the regular diff equation to solve for the coefficients... trying a particular solution, i am unfamiliar with this method.
You need to look at nonhomogenous equations in two separate parts: the homogeneous equation and then the nonhomogeneous equation.
For your problem, the homogeneous problem is y'' = 0, to which the solutions are y = c1 + c2t.
Any linear combination of the functions 1 and t (i.e., any sum of constant multiples of 1 and t) will end up at 0 when you take the derivative twice, so a particular solution can't be 1, or t or any constant multiple of these.
One function whose 2nd derivative is t2 is t4, so for a particular solution to the nonhomogeneous problem, I suggest trying yp = At4. Plug this into the nonhomog. equation and solve for the value of A that works (this is called the method of undetermined coefficients, IIRC.
Your general solution to the nonhomog. equation will be y = c1 + c2t + At4, and your job is to figure out what A needs to be.
There's a lot more I could say, but it's probably in your textbook and you haven't come to it yet.
@projection don't believe when they say you are "guessing" an answer - it's not a guess it's a METHOD. If you build a template by the correct method it will ALWAYS give you a correct answer in constant-coefficient-linear DEs (that the method can handle) :)
You didn't build the correct template because you did it not by the METHOD.
I hope Mark44 explained it in a way you will understand :)
  • · Replies 33 ·
