3-phase synchronous machine => 5-phase synchronous machine
  • Thread starter Thread starter mad mathematician
    Machine Synchronous
The discussion centers on the feasibility and implications of constructing a five-phase synchronous machine as an alternative to the more common three-phase synchronous machines. Participants explore theoretical, engineering, and practical considerations related to multi-phase systems in electrical engineering.
  • One participant questions the feasibility of a five-phase synchronous machine, suggesting that the arithmetic of dividing a circle could support such a design.
  • Another participant confirms that five-phase synchronous machines do exist, particularly in servo system motors, but emphasizes that the choice of phase number is not solely based on geometric considerations.
  • It is noted that increasing the number of phases could complicate the equations involved, which raises concerns about engineering practicality.
  • A participant mentions that three phases can be doubled using transformers, indicating that three-phase systems are effective for motor applications.
  • One contributor shares an anecdote about developing a four-phase permanent magnet servo motor, highlighting the belief that it could yield more power in a compact design compared to three-phase systems.
Participants express varying opinions on the practicality and advantages of multi-phase synchronous machines, with no consensus reached on the optimal number of phases or their engineering implications.
The discussion reflects a range of assumptions about the benefits and challenges of different phase systems, including potential cost-benefit analyses that have not been detailed. The implications of phase number on performance and design complexity remain unresolved.
mad mathematician
These power systems analysis books... :oldcry:
Anyhow, I was thinking just a few moments, can you have a five phases synchronous machine as opposed to the the three phases synchronous machines?
My reasoning is pure arithemetical-geometric, I mean a circle has 360 degrees so if we look to divide such a machine into odd phases there's 3,5,9,15,45.
So is it engineerical feasible to construct such a synchronous machine? (I just think of the number of equations increased... yuk).
Yes. They exist, but are uncommon except in servo system motors.
Anyway, it has nothing to do with the arithmetic of dividing up a circle. The engineering world doesn't necessarily think 120o is prettier than 72o or 51.429o. I'm sure there is a detailed cost benefit analysis that favors 5 phases over 3, 6, or 7 phases in each application.
Next step (usually it's my 1st, actually), Google: "5-phase synchronous motors"
If you have three phases it's reasonably easy to generate double the number of phases using transformers. But, three phase mostly shines with motors and motors are reasonably easy to build with many many poles. So, it accomplishes a similar thing.
Back in the late 1990's, I was involved in the development of a four phase permanent magnet servo motor. The EE who originated the design was convinced that four phases, and trapezoidal phase currents would develop more power in the same size package as three phases and sinusoidal phase currents. Since a 9.9 inch diameter by 16 inch long motor was conservatively rated at 225 ft-lbs continuous torque, and peak rated at 600 ft-lbs peak torque, nobody argued with him.
  • · Replies 19 ·
  • · Replies 49 ·
  • · Replies 40 ·
