Undergrad What does the equation dΩ32 = dr2 + r2dΩ22 mean in terms of flat space?
The equation dΩ32 = dr2 + r2dΩ22 describes the geometry of a 3-sphere in terms of flat space, emphasizing that while n-spheres can be embedded in higher-dimensional spaces, they do not require such embeddings for definition. A 1-sphere is a circle in 2D space, while a 2-sphere is the boundary of a 3D ball, and a 3-sphere is the boundary of a 4D ball. The discussion clarifies that the concept of flatness does not apply to n-spheres for n greater than 1, as parallel lines cannot remain parallel on these surfaces.
  • Understanding of differential geometry
  • Familiarity with topology concepts
  • Knowledge of n-spheres and their properties
  • Basic grasp of Euclidean space dimensions
  • Study the properties of n-spheres in differential geometry
  • Learn about the implications of embedding spaces in topology
  • Explore the concept of curvature in higher dimensions
  • Investigate the physical interpretations of higher-dimensional spaces
Mathematicians, physicists, and students of cosmology who seek to deepen their understanding of geometric properties and the nature of higher-dimensional spaces.
knowwhatyoudontknow
TL;DR
3-spheres in the context of curvature.
A 1-sphere exists in 2D space. It is a circle in flat space.
A 2-sphere is a 1-sphere embedded in 3D space. Its surface is non flat and 2 dimensional.
A 3-sphere is a 2-sphere embedded in 4D space. Its surface is non flat and 3 dimensional.
What does this last sentence mean in layman's terms? What is the physical meaning of the 4th dimension? Also, can the 2 and 3-spheres be defined in terms of flat space?
Space news on Phys.org
Those are mathematical definitions. There is not necessarily anything physical to them.
Furthermore, since this is the cosmology forum, it should be pointed out that the existence of an embedding space is not required. The constructions you mention are just possible embeddings of an n-sphere but each n-sphere can be well described without an embedding space through differential geometry and topology.
Likes hutchphd and PeroK
Not necessarily. A circle is a manifold in its own right, independent of any embedding in a higher dimensional space. This is also true of n-spheres for n greater than 1.
This is obviously false; a 2-sphere is a 2-sphere, not a 1-sphere.
This is also obviously false; a 3-sphere is not a 2-sphere.
Correct statements for n-spheres would be that they can, in general, be embedded in a higher dimensional flat space. But they do not need to be.
Likes hutchphd and Orodruin
In layman's terms.
1-sphere is just a circle. 2-sphere is the regular run-of-the mill sphere.
In both of those cases you're concerned with just the boundary of respectively a 2D disc and a 3D ball.
For a disc to have a meaning, you need 2D space - you need to be able to walk forward and back, left and right to reach every place on the disc. But the boundary doesn't need to be embedded in 2D space to have a meaning. All you need to travel the entirety of a circle, is go forward or back - i.e. the space you're in has just one dimension. You can, if you like, imagine the circle embedded in 2D space, which makes it easy to intuitively see the meaning of the radius of the circle. But it's not necessary. The radius can exist just as an abstract concept that tells you how long you have to go in either direction before you get back to where you started. Which is to say the embedding is optional.
Same goes for the 2-sphere, which is the boundary of a ball in 3D space. You need 3D space to reach every point of the ball - you need to be able to go forward and back, left and right, and up and down.
But the boundary doesn't need the 3D space to have a meaning. All you need to reach every spot on the surface of a ball is to be able to go left or right, up or down. I.e. the surface has two dimensions.
Again, there's the concept of the radius, which is easy to picture if we imagine the sphere as being embedded in 3D space. But, again, you don't explicitly need 3D space to fully define the sphere - the radius can very well exist just as a concept that tells you how much straight-line walking on the surface you have to do before coming back to where you started.
And again this is the same for the 3-sphere. You could try to imagine embedding it in some 4D space that requires four kinds of independent directions to travel to every point inside the 4-dimensional ball of which the 3-sphere is a boundary. But you don't need to. You can have just the 3D space of the boundary, which curves back upon itself in a manner defined by the radius of the 3-sphere. The fourth dimension needn't have any physical meaning to have a physically meaningful 3-sphere.
Now, you can't have n-spheres be flat spaces. For any n=>2 sphere to be a sphere, parallel lines can not stay parallel. For n<2 spheres the concept of flatness makes little sense, as you can't draw parallel lines on a circle or a line segment.
Likes Imager
While this is applicable if the circle or 2-sphere is embedded in 2D or 3D Euclidean space, respectively, as has already been commented, no such embedding is required to define the n-spheres.
Peter. Come on. The entire reminder of the post repeatedly hammers that in.
Likes andrew s 1905 and ergospherical
Thank you for your responses. I think I have a much better (but maybe not complete) understanding now.
I have been watching this video:
At 23:00, Prof. Susskind writes:
32 = dr2 + r222 for flat space.
Which is still a little confusing to me regarding interpretation.
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 34 ·
  • · Replies 47 ·
