3D Projectile Motion: Finding Y and Z Coordinates of Landing Position of Ball
The problem involves a perfectly spherical ball launched horizontally with specified linear and angular velocities, and seeks to determine the landing position in terms of its y and z coordinates. The context includes considerations of rotational and translational kinetic energy, as well as the effects of angular velocity on projectile motion.
  • Participants discuss the calculation of the y coordinate using basic kinematic equations, while expressing uncertainty about the z coordinate. Questions arise regarding the impact of angular velocity and the forces acting on the ball, particularly in relation to the Magnus effect.
The discussion is ongoing with participants exploring various interpretations of the problem. Some have provided hints and clarifications regarding the nature of angular velocity and its implications, while others question the assumptions made about forces acting on the ball.
There is a lack of clarity regarding the definitions of angular velocity and the conditions of the experiment, including the absence of wind. Participants also note that the problem may require additional data to fully address the z coordinate.
anmanc
A perfectly spherical ball is launched horizontally with a linear velocity of 9.9 m/s and an angular velocity (perpendicular to its trajectory) of 4.1 m/s. The ball's mass is 5.0g. (Diagram for explanation of coordinate system)
http://img221.imageshack.us/img221/2341/dddlcv.png
Find the landing position of the ball (its y and z coordinates).
b. If the rotational kinetic energy is increased by 10%, find the new landing position of the ball.
Rotational KE = .5Iw^2
For a perfectly spherical projectile, I = 2/5 (MR^2)
Translational KE = .5mv^2
[PLAIN]http://www.sentynel.com/suvat.png
For y coordinate, simply use v=x/t in x direction to find t - t=x/v=4.102/9.9=0.414s.
then, since in the y direction u=0 and a=9.8m/s^2, s=ut+.5at^2=0.83m above the ground on the wall.
I have no clue how to go about the z coordinate. Please help, someone.
Hint: There isn't any difference between motion in the x and z direction assuming Fz=0.
But how can Fz equal zero if there is clearly a spin and angular velocity in its direction. Furthermore, this is a question to obtain a theoretical model based off of experimental data which clearly shows an angle phi (between the landing position and the launching device) in the z direction. This is what I am trying to figure out - how to calculate that deviation and perhaps the angle based on the data given. Is that possible?
Could you be more clear about what due you mean when you say "angular velocity"? You say that the angular velocity is 4.1m/s in the z direction. This does not make sense angular velocity is measured in rad/s.If the angular velocity of the ball is 4.1 rad/s in the z direction it means that the ball spins clockwise along the z axis. This is clearly not what you want.
What exactly is the launching apparatus?
Is there wind in the z direction?
What type of ball is it? Is it big enough to be influenced by the wind?
Sorry for the lack of clarity.
I misused the terminology; I meant side spin speed. 4.1m/s is the speed of the side spin. Another calculation of the same concept that I have is just rate of spin, which is 17.8 rps again in the z direction. By the way, it is anti clockwise rather than clockwise.
The launching apparatus is a tennis ball machine. The machine has two horizontally placed wheels that have variable speeds; the ball is placed between them and launched through, so there is side spin (the ball's trajectory is rightward). The ball being launched isn't a tennis ball though, it is the equivalent of baseball without the stitching. There is no wind.
I still don't completely understand your terms but I will try.
So initially the ball spins around your y-axis (a point on the ball would go towards positive z if you looked from the wall)?
The angular velocity of the ball is w=17.8rps=35.6pi rad/s. ( A measure of how fast it spins around it's axis of rotation)
Since the there isn't any wind the only force in the z direction would be the Magnus force but the problem doesn't appear to give enough info to find it.
http://en.wikipedia.org/wiki/Magnus_effect
Thank you. Is there is no other way to calculate the z co-ordinate without this data?
But to see how it would be solved with the required data, let's assume the air resistance coefficient is 0.3.
The angular velocity will not affect the flight path unless you want to get into an aerodynamic model, which is fairly complicated. Without that factor, it's a simple projectile motion problem. With aerodynamics factored in, you can't just arbitrarily decide on an "air resistance coefficient". You could assume a coefficient of drag (which would probably be around 0.7), but the spin would still not affect the solution. For the spin to affect the solution, you would need to introduce a model with a coefficient of lift that is a function of the induced circulation of the fluid flow. That is a somewhat nontrivial calculation.
