3d projectile motion, with rotating reference frame
23 replies · 12K views · last reply
Jimbone
I'm using MATLAB show the path of a projectile fired directly up(directly out from the center of the earth) from 41 degrees north latitude. Air resistance, variation of gravity cause by height, and the centrifugal force are for now ignored. What I'm trying to figure out is why there is a north deflection of the projectile. That is why does the object land north of where it was fired while there was no initial north/south velocity or displacement.
Hand-drawn diagram of a sphere with a vertical north-south axis, a curved arrow at the north pole showing rotation, and arrows labelled j direction (y), k direction (z) and i (x) heading east.
I've ruled out gravity because it will only act in the up/down direction (until the object is deflected north/south then it will have some impact). I'm thinking that it has to do with the up/northward direction of the angular velocity of the earth. It is perfectly parallel with the Earth's axis of rotation. Here are my plots.
MATLAB 3D plot of a projectile path with axes x (times 10^4), y and z (times 10^5); the curve rises steeply from near y=0 to z about 5 x 10^5 and then descends toward positive y.
Line graph of North/South Deflection (y-axis, 0 to 700) against time (x-axis, 0 to 700), a blue curve rising from near zero and steepening to about 600 at time 600; a box labelled north with an upward arrow sits above it.
Any thoughts?
What happens when it is fired from the southern hemisphere & what happens if you modell the Earth spinning in the opposite direction??
And what are your units here (how high does the projectile reach)? If you have neglected the variation of height with gravity then maybe this assumption is not valid and you are getting the Northern deflection because of a computational reason.
Can you post your code?? (commented if poss).
One final question... the most important one I've asked... have you modeled the Earth's rotation? If you have then I agree with the program for reasons I will disclose.
I have modeled the Earth's rotation consistent with 2pi/1 day. The projectile reaches a height of about 4.5 x 10^5 meters. I haven't tried changing the direction of the rotation of the earth, as I'd rather not find all of my differential equations again. However I have found that when the z(up/down) velocity is positive, the projectile accelerates away from the equator and towards the pole. While if the z velocity is negative the projectile accelerates towards the equator. The acceleration in y(north/south) is directly relation in a parabolic curve to the velocity of z. Sometime this weekend I will add the forces neglected, air resistance, variation of gravity and the centrifugal force.
I'm using a typical MATLAB ode solver, file with solver and plot statements has been left out.
Here are my differential equations:
function d_dt = rocketball(t,r)
global w lambda g
d_dt = zeros(4,1);
d_dt(1)= r(2)
d_dt(2)= 2.*(r(4).*w.*sin(lambda)-r(6).*w.*cos(lambda))
d_dt(3)= r(4)
d_dt(4)= -2.*r(2).*w.*sin(lambda)
d_dt(5)= r(6)
d_dt(6)= -g+2.*r(2).*w.*cos(lambda)
where r(1) = x position, d_dt(1) = dx/dt
r(2) = x velocity, d_dt(2) = dVx/dt
r(3) = y position, d_dt(3) = dy/dt
r(4) = y velocity, d_dt(4) = dVy/dt
r(5) = z position, d_dt(5) = dz/dt
r(6) = z velocity, d_dt(6) = dVz/dt
lambda = 42 degrees north latitude, g = 9.81 m/s^2, w = angular velocity = 2pi/1 day
Some interesting plots...
Line graph of acceleration in Y against time in seconds, with Z velocity labels on the axis: a blue curve rises from zero to a peak near 4.8 x 10^-3 around 300 s, then falls back to zero near 620 s.
Plot of acceleration in Y (x 10^-3) against Z velocity in m/s, showing a downward-opening parabolic curve that peaks near zero Z velocity and falls to zero at about 3000 and -3000 m/s.
thanks.
"However I have found that when the z(up/down) velocity is positive, the projectile accelerates away from the equator and towards the pole. While if the z velocity is negative the projectile accelerates towards the equator."
This statement is true in either hemisphere.
OK, I want to confirm that your vector multiplication for the acceleration was:
[tex]\ddot{\mathbf{r}} = - \dot{\mathbf{r}} \times \mathbf{\omega}[/tex]
In which case only your [itex]a_y[/itex] has the correct sign. I was curious as to why you put a factor of 2 in front of these??
Also, there is no need for you to model centrifugal force (you already have by your choice of co-ordinate system). Centrifugal force is a ficticious force that exists due to a frame of refrence that has angular momentum, you are "watching" the Earth rotating so you don't need to model this. To explain a little better, if there was was no gravity, your ball would just continue its path in the x direction. From the frame of reference of the Earth surface, this would be observed as some unknown force making the ball fly off into the sky (this force would be the centrifugal force)... I hope that explanation was adequate :P
I believe it is this force that is causing your object to fly North (however, if you put the vector multiplication the correct way round it would end up South). This is inline with the apparent gravity experienced by objects on rotating masses.
I'm actually using a rotating reference frame, that is the origin of my frame is at rest with the earth. The equation of motion in this rotational reference frame I'm using is:
m[tex]r\ddot{}[/tex]= m[tex]\vec{}g[/tex]-2m[tex]\vec{}\omega[/tex]X[tex]\dot{}r[/tex]
where...
omega is parallel to the axis of rotation and in the j and k direction (up and north)
<math display="block" xmlns="http://www.w3.org/1998/Math/MathML">
<mrow>
<mover accent="true">
<mi>&omega;</mi>
<mo>&rarr;</mo>
</mover>
<mo>=</mo>
<mi>&omega;</mi>
<mi>cos</mi><mo>&ApplyFunction;</mo>
<mfenced open="(" close=")" separators=",">
<mrow>
<mi>&lambda;</mi>
Ok so, in rotating reference frame:
[tex]\frac{\rm{d}^2\mathbf{r'}}{\rm{d}t^2} = \frac{\rm{d}}{\rm{d}t}\left(\dot{\mathbf{r}} + \omega\times\mathbf{r}\right)[/tex]
So expanding this out I get...
[tex]\frac{\rm{d}^2\mathbf{r'}}{\rm{d}t^2} = \ddot{\mathbf{r}} + \mathbf{\omega}\times\dot{\mathbf{r}} + \mathbf{\omega}\times(\dot{\mathbf{r}} + \mathbf{\omega}\times\mathbf{r})[/tex]
[tex]\frac{\rm{d}^2\mathbf{r'}}{\rm{d}t^2} = \ddot{\mathbf{r}} + 2\mathbf{\omega}\times\dot{\mathbf{r}} + \mathbf{\omega}\times( \mathbf{\omega}\times\mathbf{r})[/tex]
So I think your equation should be
[tex]m\ddot{\mathbf{r}} = -mg -2m(\mathbf{\omega}\times\dot{\mathbf{r}}) - m\mathbf{\omega}\times( \mathbf{\omega}\times\mathbf{r})[/tex]
I got to go now, I'll pick this up tomorrow if someone else doesn't... good luck
yeah that's what I used, the last term the wx(wxr) is the centrifugal force I believe which is absent in my first calculation. Thanks for your help
Good good, that's what I was about to say, the centrifugal force is modeled and doesn't need to be added. OK, that just leaves the sign of the vector product under question, I still think that your accelerations from the vector product term should have a minus (I previously thought the y-acceleration needed a minus too but I think that should be positive now).
where...
Generally the contribution from the centrifugal term is larger than the contribution from the coriolis term. In the vast majority of scenario's the projectile will land significantly south of the latitude where it was fired from
As a means of verification you can set up a parallel compuation that evaluates the trajectory relative to the inertial coordinate system. The total initial velocity is the vector sum of the gun's nozzle velocity and the prior-to-launch velocity of co-rotating with the Earth. With the trajectory known you can transform those data to the rotating coordinate system.
The two computation strategies are comparable in complexity; in the case of the inertial coordinate system you have only a single acceleration factor: gravity; in the case of the rotating coordinate system you have to evaluate three acceleration terms: gravity, centrifugal, coriolis.
thanks I might give that a try. When I set the initial conditions consist with a gun fired parallel to the Earth's surface, the deflection is southward or towards the equator. But for some reason when the initial velocity is directly up the deflection is northward.
Just out of curiosity, what do you count as 'deflection' here?
For instance, take the case of firing a projectile from the surface of a non-rotating planet, fired parallel to the surface. Will that projectile land on the latitude that it is fired from?
** Later edit: my apologies, the statement is incomplete. I mean: fired parallel to the surface and parallel to the latitude line **
Answer: No: the projectile will always land closer to the equator than the latitude it is fired from.
Think of the line of intersection of a plane and a sphere (with the plane going through the sphere's geometric center.) Let that plane be tangent to the circle of 41 degrees latitude. To either side that line of intersection extends towards the equator.
So that's not a deflection. A projectile in orbital motion does not deflect (it's deflected down, by gravity, but not sideways). But the projectile does proceed towards the equator. - On a non-rotating planet, if you fire straight up (perpendicular to the local surface), the projectile will land on the spot where it was fired from.
- On a rotating planet, if you fire straight up the projectile has a tangential velocity that comes from co-rotating with the planet prior to the launch. For that reason alone it will proceed to the equator.
Hence my question: what do you count as 'deflection'?
I suppose by deflection I mean any movement in the x-y plane where the initial velocity is in the z direction.
The direction of the motion(I'm going to restrain from calling it deflection) of a particle in the x-y plane, parallel to the surface of the earth, when given some initial z(up) velocity or displacement is dependent upon those initial conditions.
For example:
An object dropped from a tall building will land east of its initial east/west displacement. However when an object is fired upwards instead it will land west of where it began.
In my model the object launched directly up in the northern hemisphere lands north of its original position. Are you saying that this is incorrect?
Graph of acceleration in Y against Z velocity in m/s, a downward-opening curve peaking near 4.9 x 10^-3 at zero Z velocity and reaching zero near 3000 and -3000 m/s.
Yeah, dead certain the model is incorrect if it does that; it goes against physical law.I repeat: a ballistic trajectory is orbiting motion (except that the orbit is too close, and the projectile impacts on its way back.)
Orbiting motion is planar. You intersect the plane of the orbit with the Earth's surface; that line of intersection is a great circle. That great circle is the groundtrack of the orbiting motion. That groundtrack is tangent to the starting latitude. So in the case of firing straight up (perpendicular to the local surface) there is no way the projectile can land further away from the equator than the starting latitude.
This seems very strange to me. First of all how does a non-rotating planet have an equator? With out the rotation it seems impossible that the projectile wouldn't stay in two dimensions. My model shows a only two dimensional motion.
What you're saying about this being a simple case of planar orbit makes a great deal of sense. However, consider this:
From what you're suggesting(and what I've seen in the past) an object fired parallel to the surface along a latitude would drift towards the equator. Given its initial trajectory is only in an east/west direction the south/north drifting would have to be a parabolic-like curve, not linear. So with a curved trajectory in both the north/south plane and the up/down plane the motion could not be restricted to a plane.
What causes this north south drifting anyhow? And what mistake in my equations of motion account for the northward drifting?
Also I shouldn't have left out the fact that I'm neglecting the curvature of the earth, as well as the centrifugal force, air resistance, and variation of gravity.
Cleonis' post provides remarkable insight to this North/South motion, and I would suggest that the equator exists as a choice of co-ordinate system (polar in this case), not the objects rotation.
As for the restricted plane comment, you can't forget that you have modeled an inertial reference frame from the rotation of the Earth. The plane you have defined as North/South-East/West changes with rotation of the Earth.
I still think that modifying your code will predict a Southernly trajectory as predicted. The North-South drift is due to that the Coriolis force works in the direction perpendicular to the plane of the angular velocity and trajectory velocity (which is going to be East-West initially).
I don't think this has been addressed, but when I was working through this problem I found that I didn't change the latitude to radians from degrees. This dramatically changed my result, however I still had a northward deflection. Also, it should be noted that:
"The Coriolis force acts in a direction perpendicular to the rotation axis and to the velocity of the body in the rotating frame" (http://en.wikipedia.org/wiki/Coriolis_effect)
The equations of motion that we found have only an initial k' velocity. This starts an acceleration in the negative i' direction which forces a northern deflection
Hi. I have a question.when the force on a projectile which moves in a fluid is:
F= -avV +bW X V
and the torque is : τ= -v(cW(vertical)+c’W(parallel))
V is the velocity of a sphere(is a vector)&W is the angular velocity of sphere(is a vector)
V & W don't have a constant direction during the motion of sphere.
How we can find equation of motion for this sphere?
