pags920
- 20
This is basically a continuation of a previous problem I submitted. I worked out the previous problem, now I need to figure out another problem. This 4-bit shift register won't load the number I am trying to load. I have exhausted every possible error where it could be wrong. I commented lines out to see if I could pinpoint it, but I cannot seem to find out why it won't load my number. This was done using Verilog.
If anyone can figure out where the typo is so I can load the register with a value, that would be most helpful.
Code:
module t_Shift_Register_4_str;
wire [3:0] a_par;
reg [3:0] i_par;
reg s1,s0,msb_in,lsb_in,clk,clear,select;
Shift_Register_4_str m0(a_par,i_par,s1,s0,msb_in,lsb_in,clk,clear,select);
initial #100 $finish;
initial begin clk=0; forever #10 clk=~clk; end
initial fork
#0 i_par=4'b0100; clear=1; select=1;
#0 s1=1'b1; #20 s1=1'b1; #40 s1=1'b0; #60 s1=1'b0;
#0 s0=1'b1; #20 s0=1'b0; #40 s1=1'b0; #60 s0=1'b1;
#0 msb_in=1'b1;
#0 lsb_in=1'b1;
join
endmodule
module Shift_Register_4_str (A_par,I_par,Select,s1,s0,MSB_in,LSB_in,CLK,Clear);
output [3:0] A_par;
input [3:0] I_par;
input [1:0] Select;
input s1,s0,MSB_in,LSB_in,CLK,Clear;
assign {Select[1],Select[0]} = {s1,s0};
stage ST0 (A_par[0],A_par[1],LSB_in,I_par[0],A_par[0],Select,CLK,Clear);
stage ST1 (A_par[1],A_par[2],A_par[0],I_par[1],A_par[1],Select,CLK,Clear);
stage ST2 (A_par[2],A_par[3],A_par[1],I_par[2],A_par[2],Select,CLK,Clear);
stage ST3 (A_par[3],MSB_in,A_par[2],I_par[3],A_par[3],Select,CLK,Clear);
endmodule
module stage (i0,i1,i2,i3,Q,select,CLK,Clr);
input i0,i1,i2,i3;
output Q;
input [1:0] select;
input CLK,Clr;
wire mux_out;
Mux_4_x_1 M0 (mux_out,i0,i1,i2,i3,select);
D_flip_flop M1 (Q,mux_out,CLK,Clr);
endmodule
module Mux_4_x_1 (mux_out,i0,i1,i2,i3,select);
output mux_out;
input i0,i1,i2,i3;
input [1:0] select;
reg mux_out;
always @ (select or i0 or i1 or i2 or i3)
case ({select})
2'b00: mux_out = i0;
2'b01: mux_out = i1;
2'b10: mux_out = i2;
2'b11: mux_out = i3;
endcase
endmodule
module D_flip_flop (Q,D,CLK,Clr);
output Q;
input D,CLK,Clr;
reg Q;
always @ (posedge CLK or negedge Clr)
if(~Clr) Q<=1'b0; else Q<=D;
endmodule
