Gauss's Trick - Arithmetic Sums
  • Thread starter Thread starter Johnathanrs
    Arithmetic Sums
Gauss's Trick simplifies the calculation of the sum of a series of integers using the formula n/2(f+l), where n is the total number of integers, f is the first integer, and l is the last integer. The method involves pairing the first and last integers to reveal a consistent sum across the pairs, demonstrating that the total can be calculated efficiently. By writing the integers in ascending and descending order, one can observe that each column sums to the same value, reinforcing the pairing concept. This approach not only provides a quick way to calculate sums but also illustrates the underlying arithmetic principles. Understanding this method can enhance mathematical comprehension and problem-solving skills.
Johnathanrs
I can't grasp the underlying process on how this is working.
n/2(f+l) = algorithm sum of all integers
n= number of all integers
f= first integer
l= last integer
Example: 1, 2, 3, 4
4/2(1+4)
2(5) = 10
I know how to do it, but I don't really understand how to actually do it. Am I just too stupid?
Why do I need to split the sum of all integers?
Why am I adding the first + last integer?
Why when I times them together does it work?
How did he create the algorithm for this?
Mathematics news on Phys.org
In order to see how this works, write down the string of integers in two different ways:
Code:
 1  2  3  4  5  6  7  8  9  10
10  9  8  7  6  5  4  3  2   1
What do you notice about the sum of each column of numbers?
What Gauss did (according to the usual story) was to pair off the numbers like this.
Suppose you want to sum the 9 numbers 7 8 9 10 11 12 13 14 15
7 + 15 = 22
8 + 14 = 22
9 + 13 = 22
10 + 12 = 22
11 = 22/2
So the sum = (9/2)(22) = (9/2)(7+15)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
