Therefore, R's=0.057/26.5^2=0.000078 Ω2% of 415 V is 8.3 V
  • Context: Engineering
  • Thread starter Thread starter andyskin
    Transformer
The discussion focuses on calculating the voltage regulation of a transformer with a primary winding voltage of 415V and a secondary winding voltage of 11kV, rated at 200KVA. The equivalent winding resistance (Rieq) is 0.14 Ω, and the equivalent leaking reactance (Xieq) is 0.057 Ω. The voltage regulation at a 0.8 power factor lagging is determined to be 5.272%. Additionally, the transformation ratio (k) is calculated as 26.5, which is essential for further resistance calculations.
  • Understanding of transformer voltage regulation calculations
  • Familiarity with power factor concepts and calculations
  • Knowledge of equivalent circuit parameters such as resistance and reactance
  • Basic grasp of transformer ratings and their implications
  • Study transformer voltage regulation formulas in detail
  • Learn about the impact of power factor on transformer performance
  • Explore advanced transformer equivalent circuit models
  • Investigate the effects of load conditions on transformer efficiency
Electrical engineers, power system analysts, and students studying transformer operations and voltage regulation techniques will benefit from this discussion.
andyskin
A 415V to 11 kV transformer has a rating of 200 kVA. The winding resistance
and leakage reactance when referred to the primary are 0.014 Ω and 0.057 Ω
respectively.
(a) Determine the % regulation of the transformer at 0.8 power factor lagging.
(b) In designing a particular 415V to 11 kV, 200 kVA transformer, the primary
winding resistance is to be 10 mΩ. Find the maximum winding resistance of the
secondary winding if the transformer is to have 2% regulation at unity power
factor.
Primary winding voltage v1 = 415V
Secondary winding voltage v2 = 11kv
Rating of transformer is 200KVA
winding resistance Rieq = 0.14 Ω
winding leaking reactance Xieq = 0.057 Ω
A) % regulation at 0.8 power factor lagging
Primary winding current I1 = 200/415 = 482a
Power factor CosΦ = 0.8 lag
SinΦ = 0.6
% Voltage regulation = I1Rieq/V1 cosΦ + I1Xieq/V1 SinΦ
= (482x0.014/415)x 0.8 + (482x0.057/415)x0.6
= 0.013 + 0.038972
= 0.05272
= 5.272%
B) Primary winding resistance R1 = 10mΩ = 0.01Ω
Power factor = cos Φ = 1
sin Φ = 0
% Voltage regulation = I1Rieq/v1 cosΦ + I1Xieq/v1 sinΦ
0.02 = 482xRieq/415 x1 + 482xXieq/415 x 0
482x0.014/415 x1 + 482x0.057/415 x 0
= 0.0162
Where k is transformation ration
K = N2/N1 = V2/V1 = 100/415 = 26.5
0.0162 = 0.01 + r2/26.5√
r2/25.5√ = 0.0072
r2 = 5.0585 ΩNot sure if I'm correct , the course notes are not much good
a) it is correct.
b) How much is 2% of 415 V?
Req=Rp+R's
R's=Rs/k^2 k=11/.415=26.5 indeed.
  • · Replies 16 ·
9K
  • · Replies 33 ·
10K
