A ball is thrown upward direction , is it a -ve displacement
The discussion clarifies that the concept of displacement when throwing a ball upward is dependent on the chosen coordinate system. It establishes that one can arbitrarily define the positive direction, either upward or downward, without affecting the physical results, as long as the convention is consistently applied. For instance, when throwing a ball from the ground upward, the upward direction is typically defined as positive, while throwing from a tower may result in negative displacement if downward is defined as positive. The force of gravity is considered positive when the displacement is negative during upward motion.
  • Understanding of basic physics concepts such as displacement and force.
  • Familiarity with coordinate systems and their applications in physics.
  • Knowledge of gravitational force and its effects on motion.
  • Ability to apply conventions consistently in physics problems.
  • Research the principles of coordinate systems in physics.
  • Learn about displacement and its implications in kinematics.
  • Explore the effects of gravity on projectile motion.
  • Study examples of arbitrary conventions in physics problems.
Students of physics, educators teaching kinematics, and anyone interested in understanding the principles of displacement and motion in relation to gravitational forces.
md abul hasan
when a ball is thrown in upward direction --how can it be a negative displacement?
You have the choice to say that the axis perpendicular to the ground points upward or downward (i.e., in the direction of gravity). It is purely arbitrary and won't affect the results, provided that the convention chosen is strictly adhered to: once you've chosen which way is positive, stick to it!
It is an arbitrary choice. Having made a choice one simply has to be consistent.
If one were considering a situation where one is standing on the ground throwing a ball upwards so that all distances are up, it would be sensible and simplest to say up is positive.
If one were throwing objects off the top of a tower so that most of the displacements were below the starting point, one could well choose to take the starting point at the top of the tower as zero and make the downwards direction positive. Then, if one did throw a ball upwards, its displacement would be negative until it fell past the top of the tower.
is toward gravity +ve ?
Yes, if the throwing the ball upwards results in a negative displacement, then the force of gravity is positive.
  • · Replies 38 ·
  • · Replies 16 ·
