A basic question about Photoelectric effect
4 replies · 2K views
docnet
Light of wavelength 500 nm is incident on sodium, with work function 2.28 eV. What is the maximum kinetic energy of the ejected photo- electrons?
##KE=\frac{hc}{\lambda}-Work##
The energy of a photon with wavelength ##\lambda=500nm## is given by the equation
##E_{photon}=h\nu=\frac{hc}{\lambda}##.
##E_{photon}=3.614\times10^-19 J=2.256eV##
The kinetic energy of an ejected photo-electron is given by
##KE_{electron}=E_{photon}-Work##
Using the given ##\lambda## and the kinetic energy of the photon,
##KE_{electron}=2.256eV-2.28eV=-.024eV##
The maximum kinetic energy of the ejected photo-electron is ##-.024eV##
The energy of the photon is insufficient to eject an electron from sodium.
haruspex said:
I looked up 500nm at https://www.omnicalculator.com/physics/photon-energy and got 2.48eV.
Thank you! I am getting pretty careless, because I think I put in ##550nm## into the calculator instead of ##500nm##, which explains the discrepancy.
##\frac {(6.626\times10^{-34} \frac{m^2kg}{s})(3\times10^8 \frac{m}{s})}{(5\times10^{-7}m)(1.602\times10^{-19} \frac{eV}{J})}=2.48eV##
The correct solution is
##KE_{electron}=2.48eV-2.28eV=.20eV##
The maximum kinetic energy of the ejected photo-electron is ##.20eV##.
mjc123 said:
When you got a crazy answer, didn't you do the calculation again to check?
No emission is not a crazy answer. It could have been a trick question.
But yes, certainly should trigger a careful recomputation or two. Or cheat, like I did.
