DevilsAvocado
- 91
DrChinese said:I have been called a virus by some people...
Caroline H. Thompson?
It should definitely help to follow this discussion.billschnieder said:There is so much confusion that I would like to start my participation in this thread by suggesting that we each define what we mean by "realism".
I would say that while this definition is "true" it is not restrictive enough to have some value.billschnieder said:To me, realism means, "elements of reality" exist independent of observation, or observability. To me realism has nothing to do with instrumental behaviour or whether these "elements" can be directly observed without disturbance or not. To me, when you say a photon is emitted but not detected, you are admitting to my definition as above. As far as I can tell from this thread so far, all participants believe realism as defined above is true even if they haven't explicitly admitted it. If anyone else thinks realism as defined above is false, please state it and I will show using your own quotes that you are lying. However, you may think "realism" means something else and it is important we all agree what we are arguing for or against to avoid confusion.
This is not EPR definition. EPR definition covers only the case when say projection of spin is predictable with certainty. And because this definition involves "prediction" it can start a looong discussion.billschnieder said:Now some will argue that the EPR definition of realism is the idea that a single particle (or entangled pair) will have definite spin projections at 3 different angles. I do not agree that this is the EPR definition but I am willing to grant that definition for the sake of argument, so long as we are not later on drawing conclusions about the previous definition I gave above, based on this so called "EPR definition". In any case, I will suggest first that we present clearly the definition of realism we would like to argue, and then when all the parameters of this version of "realism" have been exposed, it will then make sense to question whether QM or Experiments in anyway tell us anything about the "realism" we are discussing.
If we can relate event that has happened before (memory) with another event that just happened (senses) then event in memory is cause by definition and event reported by senses is effect by definition and to say that effect and cause can swap places means that we should alter memory and simulate sensory information. But in that case we can't be sure about anything and I prefer to be sure about something rather than nothing.Dmitry67 said:For me, Effect is in the lightcone of Cause, nothing more. (In CTL it could be laso vice versa). But then (in flat spacetime) Effect is always after the Cause - just by definition!
DevilsAvocado said:Caroline H. Thompson?![]()
billschnieder said:Fair enough.
It is the spin which pre-exists the observation, not the "spin projection", yet it is the "spin projection" which is observable not the spin. So clearly, if the EPR definition is that "observables must pre-exist measurement", it is not a reasonable definition because as you have agreed in (1), realism simply means "elements of reality" (not "observables") pre-exist observation". In other words, it is possible for realism as defined and agreed in (1) to be true, in a completely contextual universe in which nothing can be directly observed, but in which pre-existing elements of reality always interact with instruments to reveal observables. But contextual observables are not allowed in a universe in which observables must pre-exist observation.
If the EPR definition is that "observables must pre-exist observation", then contextual observables are not allowed. But in my definition, contextual observables are fully consistent with pre-existing "elements of reality". But if you are willing to agree that underlined text above is not the EPR definition, and will rather say that my original definition which you agreed to is the EPR definition, then that is a good point to start, and we can proceed to discuss the burden of proof required to disprove it.
DrChinese said:1) Since the result is certain, there is little point in distinguishing the two.
2)You call that a contextual measurement, and I do not define as such. Because the result is certain, it is non-contextual. I view contextual as meaning that the entire context, including spacelike separated components, is relevant. That would not be possible in a classically local world (but would in a quantum local world).
billschnieder said:Now continuing with the discussion about realism, since we have a working definition to continue with, I have a question:
If a single particle is real and has a pre-existing spin, according to realism, we would say measuring the spin-projection in a completely specified context, will result in a definite outcome. We can therefore define three or any number of different contexts "a", "b", "c", ... for the single particle for which we will obtain a definite result if we measure the single particle in that context. Do you agree that, this paragraph accurately. represents what a realist will say about the particle?
Non-realism will respond that it is not possible to predict what will be obtained even by completely specifying a contexts for the single particle, since it will not result in a definite outcome. Is this a correct representation of what a non-realism may say about the situation described in the previous paragraph? If not please could you rephrase it to your liking?
DrChinese said:So I suggest we discuss around these:
http://arxiv.org/abs/quant-ph/0608008
We prove here a version of Bell Theorem that does not assume locality. As a consequence classical realism, and not locality, is the common source of the violation by nature of all Bell Inequalities.
Pio2001 said:Thus, EPR-Bell experiments show the incompatibility between experimentation and local hidden variable models
JordanL said:DrC: Does your personal inclination to reject objective realism lead you to any other assumptions or hypotheses?
Or, I suppose, does the collected work that has been done on that point of view have any other conclusions that might be testable? I would think that observational dependence in realism would imply a more fundamental interconnectedness of things that we observe to exist within our concept of reality. Would QM be sufficient to explain this greater connection? Or would a greater connection be unnecessary? If such a fundamental interdependence of existence were posited, how would it be tested?
I ask because this is an area I have not ventured very far into, and it seems you have given it more consideration.
DrChinese said:Welcome to PhysicsForums, JordanL!
I don't see rejecting realism as requiring any other assumptions. Keep in mind that there are several different interpretations that reject realism. I would say that "most" physicists reject realism in one fashion or another.
As to testing: there are "some" experiments which appear to support rejection of realism. There are a number of papers on the subject. I would say nothing to date is absolutely conclusive but that seems to be the direction. A lot of Bohmians reject realism too, or at a minimum reject non-contextuality (which to me is the same as objective realism).
I would put it this way. Strong theorems (such as Kochen-Specker) rule out SIMULTANEOUS non-contextual/objective realism of non-commuting quantum observables. E.g., if spin in z-direction is real, then spin in x-direction is not. The Bohmian interpretation exploits the fact that at most one quantity may be real in the NON-CONTEXTUAL/OBJECTIVE sense, and this quantity is (usually) taken to be the particle position. Thus, in Bohmian mechanics spin indeed is not non-contextually/objectively real, but the particle position is. So when we measure spin, we don't really measure spin (because it is not real); what we really measure are some particle positions in the Stern-Gerlach apparatus.DrChinese said:A lot of Bohmians reject realism too, or at a minimum reject non-contextuality (which to me is the same as objective realism).
Quantum nonlocality has been experimentally investigated by testing different forms of Bell’s inequality, yet a loophole-free realization has not been achieved up to now. Much less explored are temporal Bell inequalities, which are not subject to the locality assumption, but impose a constraint on the system’s time correlations. In this Letter, we report on the experimental violation of a temporal Bell’s inequality using a nitrogen-vacancy (NV) defect in diamond and provide a novel quantitative test of quantum coherence. Such a test requires strong control over the system, and we present a new technique to initialize the electronic state of the NV with high fidelity, a necessary requirement also for reliable quantum information processing and/or the implementation of protocols for quantum metrology.
No, it doesn't disprove realism. It only disproves non-contextual realism, but the violation of original Bell inequalities also does that. Bell and many others emphasize nonlocality rather than contextuality because contextuality does not look so surprising to them, not because they thought contextuality could be avoided.Zarqon said:Is it true that since the temporal Bell inequalities do not depend on locality, a violation of the inequalities in this frame directly disproves realism?
Demystifier said:I would put it this way. Strong theorems (such as Kochen-Specker) rule out SIMULTANEOUS non-contextual/objective realism of non-commuting quantum observables. E.g., if spin in z-direction is real, then spin in x-direction is not. The Bohmian interpretation exploits the fact that at most one quantity may be real in the NON-CONTEXTUAL/OBJECTIVE sense, and this quantity is (usually) taken to be the particle position. Thus, in Bohmian mechanics spin indeed is not non-contextually/objectively real, but the particle position is. So when we measure spin, we don't really measure spin (because it is not real); what we really measure are some particle positions in the Stern-Gerlach apparatus.
Thus, it is not correct to say that Bohmians reject non-contextual realism. Instead, they reject non-contextual realism for almost all quantum observables, except one.
Anton Zeilinger said:http://discovermagazine.com/2011/jul-aug/14-anton-zeilinger-teleports-photons-taught-the-dalai-lama/article_view
So does that mean Einstein was wrong?
There are still some technical loopholes in the experiments testing Bell’s theorem that could allow for a local realistic explanation of entanglement. For instance, we don’t detect all the particles in an experiment, and therefore it is conceivable that, were we to detect every single particle, some would not be in agreement with quantum mechanics. There is *a very remote chance* that nature is really vicious and that it allows us to detect only particles that agree with quantum mechanics. If so, and if we could ever detect the others, then local realism could be saved. But I think we are close to closing all of these loopholes, which would be a significant achievement with practical implications for quantum technologies.
Who is talking about 1%?DevilsAvocado said:... for that 1% to turn everything upside down ...![]()
zonde said:Who is talking about 1%?
zonde said:... coincidence rate was only around 10%
DevilsAvocado said:So, are you saying (for real) that there is 90% chance for Local Reality to survive?
