A block of mass m=0.2 kg, is pushed by a spring of stiffness k=300 N/m
The discussion revolves around a physics problem involving a block of mass 0.2 kg pushed by a spring with a stiffness of 300 N/m, initially compressed by 10 cm, on a 30° wedge with a friction coefficient of 0.6. The user struggles to arrive at the professor's stated answer of 0.56 m, despite attempting various formulas related to simple harmonic motion. Participants suggest that an energy approach may be more appropriate, considering the potential energy of the spring and the energy lost to friction. The conversation highlights the importance of clarifying whether the block is attached to the spring and the initial conditions of the problem. Ultimately, the focus is on understanding the balance of forces and energy in the system to solve the problem correctly.
selhai97
I am currently taking a physics class and I'm studying for the final and I've been stuck on this problem and haven't been able to find help from the book nor help from online.
The professor said the answer was .56m, but I've been trying formulas for about an hour now and haven't been getting anything close to that.
Help please?
1. Homework Statement
A block of mass m=0.2 kg, is pushed by a spring of stiffness k=300 N/m, initially compressed by A=10cm, up the 30° wedge. If the friction coefficient between the block and the wedge is 0.6, how far will the block pass in m along the wedge before it stops?
I think:
ω = √(k/m)
T = (2π)/ω
x = Acos(ωt + φ)
[/B]
ω = √(300/.2) = 7.7
T = (2π)/7.7 = .82
x = (10)cos(7.7*.82) = 9.99
Like I said, I've been trying different formulas for about an hour now, so I don't think I'm using the right ones.
Any help would be amazing, thank you!
Help please?
I think:
ω = √(k/m)
T = (2π)/ω
x = Acos(ωt + φ)
[/B]
ω = √(300/.2) = 7.7
T = (2π)/7.7 = .82
The problem involves a wedge at an angle, gravity, a spring and friction? I'm not sure it's a good idea to use SHM, which would be about the frequency of oscillations of the system.
PS You might want to check those numbers. Do you have a diagram?
No, no diagram, that's all the information that I was given.
The difficulty as I see it is that on a ##30°## angle, a coefficient of friction of ##0.6## more than cancels gravity. In any case, the nett force is low. With those numbers, it's effectively just the spring, with a small variation due to the slope.
Without the slope, it should move ##20cm##.
Also, even if you take friction out of the equation, the PE of the mass is low compared to the spring. Even a mass hanging on that spring wouldn't stretch it much. You could work that out.
I'd leave it. It doesn't look right to me.
Alright, well thanks anyways! I really appreciate it.
The problem doesn't specify if the block is attached to the spring or whether it is unattached, or what is to be considered the block's starting position (before the spring compression or after?).
Either way I'd suggest an energy approach.
Likes PeroK
Yes, of course, if the mass was pushed down on the spring and not attached to it!
You wouldn't use something like this right?
max = -mgsinθ
vxf2 = vxi2 + 2aΔx
max = -mgsinθ
vxf2 = vxi2 + 2aΔx
Nope. I'd deal directly with the energies (kinetic and potential). The only tricky bit is handling the spring action since the block and spring become disengaged at some point.
So PE = mgh and KE = (½)mv2?
Are there other equations that involve the A and k and μ?
I'm sorry if I'm so lost, physics is my hardest subject.
Look into formulas pertaining to the potential energy stored by a spring and the energy lost to friction.
