A charge inside a non conducting spherical shell uniformly charged
The discussion centers on the behavior of a positive charge placed inside a uniformly charged non-conducting spherical shell. According to Gauss's Law, the charge experiences no net force from the shell's charges, regardless of its position within the shell. This principle holds true as the electric field inside the shell cancels out due to symmetry, similar to gravitational forces in a spherical shell. The confusion arises when considering multiple charges inside the shell, which can interact with each other but remain unaffected by the shell's charge.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with electric fields and their properties
  • Knowledge of the concept of symmetry in physics
  • Basic principles of gravitational forces in spherical shells
  • Study the implications of Gauss's Law in different geometries
  • Explore the concept of electric fields generated by various charge distributions
  • Investigate the behavior of multiple charges within a charged shell
  • Learn about the similarities between electrostatic and gravitational forces
Students of physics, educators explaining electrostatics, and anyone interested in understanding the principles of electric fields and forces in charged systems.
tmn50
This problem is driving me mad
suppose that we have a positive charge inside a non conducting spherical shell uniformly charged
the charge is at a random place inside the shell but not in the center
the textbook says the charge will feel no force from the charges of the shell and the argument is based on gauss law when there's no charge inside the shell
this is true but when we put the charge inside everything changes
if we apply gauss law
we choose a gaussian surface that has the same center as the shell with a radius that's big enought to contain only the emptiness before the charges of the shell (if we can say that)
so there will be an electric field that will act on the charges
so either the charge moves or the shell moves
this is what i could conclude
please tell me where did i go wrong
I apologize for not following the pattern cause this isn't really a problem just a case that was mentioned in the lecture and i didn't understand
I'm confused as to what the situation is.
If there is only 1 charge inside the charged shell, the force on that point charge is zero, since the shell charges' effects cancel each other at the inside charge no matter where that charge is located. This is what your problem seems to state.
What you say after that I can't follow. If you assume two (or more) charges within the charged shell then those inside charges will attract or repel each other but still none of those inside charges will be affected by the charged shell.
It's no different than the fact that a uniformly dense spherical shell does not generate a gravitational force inside the shell. The shell simply does not exist as far as masses inside the shell are concerned. And it's exactly the same situation with the charges, since electrostatic and gravitational forces both vary inversely as the square of the distance.
12K
