A cubic foot is equal 7.48 gallons. How many cubic feet wil
  • Thread starter Thread starter jim1174
    Cubic
A cubic foot is defined as 7.48 gallons, which is crucial for converting tank volumes. In the discussion, a tank with a volume of 8000 gallons was incorrectly calculated to hold 107,527 cubic feet using the wrong conversion factor of 7.44 gallons per cubic foot. The correct conversion should use 7.48 gallons per cubic foot, leading to a more accurate calculation of approximately 1,067.5 cubic feet. Participants emphasized the importance of consistency in conversion factors to avoid significant errors in calculations.
  • Understanding of volume measurement conversions
  • Familiarity with cubic feet and gallons
  • Basic arithmetic operations
  • Knowledge of unit consistency in calculations
  • Research the implications of using different conversion factors in volume calculations
  • Learn about dimensional analysis for unit conversions
  • Explore common mistakes in volume measurement and how to avoid them
  • Study practical applications of volume conversions in engineering and science
Students, educators, and professionals in fields requiring precise volume calculations, such as engineering, physics, and mathematics.
jim1174
2. A cubic foot is equal 7.48 gallons. How many cubic feet will the tank describe in question #6 hold?
Tank has a volume of 8000 gallons.
1 feet3 = 7.44 gallons (given)
Therefore,
8000 gallon = 8000gallon x feet3/7.44gallon= 107527feet
Therefore,
Your answer should be in units of cubic feet, not feet (usually written as cu. ft of ft3). When you write exponents, at the very least use ^ to indicate an exponent.
Your numerical answer is way off. Without getting bogged down too much with numbers, let's say for the purpose of a rough calculation that a gallon is equal to 8 cu. ft. Without using a calculator, how many cubic feet would this be? You should be able to do this in your head.
Actually, a gallon is ~1/8 cu. ft.
But, jim1174, do you really think that 8000/7.48 > 100000 ?
Chet
I must have written that without thinking very hard. Yes, a cubic foot is about 8 gallons, so 1 gal. ##\approx## 1/8 cu. ft.
ok i think i got it
jim1174 said:
ok i think i got it
It depends. In your first post you have 7.44 gal./cu. ft in one place and 7.48 gal./cu. ft. in another place. Which is it?
You need to be more careful. I've seen several mistakes like this in your work.
12K
10K
