A good book on geology and/or meteorology?
The discussion revolves around recommendations for accessible books on geology and meteorology, with a focus on how geological and climatic changes occur due to various factors, including seismic activities and human impacts. Participants express interest in books that also cover planetary geology.
  • One participant seeks an easy-to-read book that discusses global geology and climate changes, emphasizing the need for detailed graphs and data, while avoiding complex physics equations.
  • Another participant suggests "Atmosphere and Ocean - Our Fluid Environments" by Harvey as a suitable recommendation, noting it covers most requested topics.
  • A different participant recommends "Skinner and Porter Physical Geology," citing it as a required textbook that addresses many relevant subjects.
  • Concerns are raised about the reliability of information in textbooks, with an emphasis on the potential for outdated ideas and the importance of consulting contemporary studies for updated perspectives.
  • One participant references Richard Feynman's lecture on the history of measurements of the electron charge to illustrate how scientific understanding evolves over time, suggesting that historical context is crucial in evaluating scientific claims.
  • There is a discussion about the ethics of scientific research, with one participant questioning whether modern theories are more reliable than past approaches, while another expresses skepticism about current practices in geophysics and meteorology.
  • Recommendations for specific authors and textbooks in meteorology are made, including "Atmospheric Science - An Introductory Survey" by J. Wallace and Peter Hobbs, noted as a classic text.
Participants express a range of opinions on the reliability of textbooks and the evolution of scientific understanding, indicating that there is no consensus on the best approach to learning about geology and meteorology. Multiple competing views on the quality and ethics of research in these fields are present.
Some participants highlight the limitations of relying solely on textbooks, suggesting that ideas presented may be outdated or contested. There is also mention of specific chapters in textbooks that may contain controversial subjects, indicating a need for caution in selecting reading materials.
Pippi
I am interested in a easy-to-read book on global geology and/or climate. The book will be ideal if it has discussions on how geology and climate changes, with detailed graphs (or data), due to seismic activities, external impacts like the solar wind from the Sun, and human-induced higher-than-otherwise chemical concentrations. It will be nice if the book has also detailed discussion of another planet in the solar system. It does not have to have discussion of the physics equations or mathematical physics simulations that are typically used.
That's a tall order in one book especially as the weather and climate spring from two unique aspects of the Earth viz its position relative to the sun and the fact that it is the only planet with both an atmosphere and liquid water so comparisons are a trifle spurious.
Try
Atmosphere and Ocean - Our Fluid Environments by Harvey
That book has most of what you asked for.
Whilst I understand that you have to start somewhere, there is a 'serious' caveat lector. What you learn from textbooks is not only data and facts but also ideas frozen in time, that may long be debunked or should be debunked.
For instance you may read in textbooks on the initial dating of the Two Creek glacial readvance by Libby et al that it is exemplary for the onset of the Younger Dryas. Later improved research unambigiously showed that this event preceded the Younger Dryas by several centuries. How hard is it though, to put question marks by the real nature of the Younger Dryas, if some of it's most 'convincing' evidence is now pointing to a completely different conclusion. So, what if your mind is set in stone, after learning and learning obsolete ideas from the textbooks.
So I would recommend for each event in textbooks, to also google comtemporary studies and see about the difference.
Edit: An example from the cargo cult lecture of Richard Feynman:
One example: Millikan measured the charge on an electron by an experiment with falling oil drops, and got an answer which we now know not to be quite right. It's a little bit off because he had the incorrect value for the viscosity of air. It's interesting to look at the history of measurements of the charge of an electron, after Millikan. If you plot them as a function of time, you find that one is a little bit bigger than Millikan's, and the next one's a little bit bigger than that, and the next one's a little bit bigger than that, until finally they settle down to a number which is higher.
Why didn't they discover the new number was higher right away? It's a thing that scientists are ashamed of--this history--because it's apparent that people did things like this: When they got a number that was too high above Millikan's, they thought something must be wrong--and they would look for and find a reason why something might be wrong.
However I don't agree with his conclusion of this phenomenon...
When they got a number close to Millikan's value they didn't look so hard. And so they eliminated the numbers that were too far off, and did other things like that. We've learned those tricks nowadays, and now we don't have that kind of a disease.
In paleo-whatever it's customary to discard carbon dates that do not agree with the consensus-; contamination, simple, without even having a notion how much contamination is required to change those dates by so much. But I guess that requires another thread.
Is it reasonable to guess that because nowadays, theories almost always precede the experiment and often cover contradictory outcomes, so we don't have such problems?
I'm afraid not. Looks like there is a big deviation from old fashion ethics, especially when subjects lead to flaming wars.
Nice discussion. Who in geophysics and metereology are epitome of quality research and ethics?
I guess there are others who can judge about geophysics. About meteorology, I'm afraid that there not a lot difference. However, I would especially recommend for the reason mentioned above to follow the restrictions in this forum and don't read about the banned subject in it, that usually is in chapter 18 or 23.
Pippi,
I would recommend Atmospheric Science - An Introductory Survey by J. Wallace, Peter Hobbs, 2nd Edition it is a classic undergraduate textbook that was updated in 2006.
  • · Replies 21 ·
  • · Replies 184 ·
50K
  • · Replies 87 ·
11K
