How Do You Calculate the Buoyant Force of a Helium Balloon?
The buoyant force on a helium balloon is calculated using the formula F_b = ρ_fluid × V × g, where ρ_fluid is the density of the fluid (air), V is the total volume displaced, and g is the acceleration due to gravity. In this case, the density of air is 1.28 kg/m³, and the volume of the balloon is determined using the formula V_sph = (4/3) × π × R³, with R being 5 m. The total mass of the empty balloon and basket is 123 kg, and the volume of the basket is 0.066 m³. The correct approach involves using the density of air for buoyancy calculations, not the density of helium.
  • Understanding of buoyancy principles
  • Familiarity with the formula for the volume of a sphere
  • Knowledge of fluid density concepts
  • Basic grasp of gravitational force calculations
  • Study the principles of Archimedes' principle in fluid mechanics
  • Learn how to calculate buoyant force in different fluids
  • Explore the effects of varying densities on buoyancy
  • Investigate the relationship between volume and buoyancy in different shapes
Students in physics, engineers working with buoyancy-related projects, and educators teaching fluid mechanics concepts will benefit from this discussion.
TMO
A helium balloon ride lifts up passengers in a basket. Assume the density of air is 1.28 kg1m-3 and the density of helium in the balloon is 0.18 kg1m-3. The radius of the balloon (when filled) is R = 5 m. The total mass of the empty balloon and basket is mb = 123 kg and the total volume is Vb = 0.066 m3. Assume the average person that gets into the balloon has a mass mp = 73 kg and volume Vp = 0.076 m3. What is the magnitude of the buoyant force on the entire system (but with no people)? Include the volume of the balloon, basket, and helium.
V_{sph} = \frac{4}{3} \cdot \pi \cdot r^3
F_b = \rho_{fluid} \cdot V \cdot g
Since the volume of the balloon and basket is given by V_b and the volume of the balloon is given by \frac{4}{3} \cdot \pi \cdot R^3, it seems natural to conclude that the magnitude of the buoyancy force is (1.28 \cdot V_b + 0.18 \cdot \frac{4}{3} \cdot \pi \cdot R^3) \cdot g, but this does not seem to provide the correct answer. Any advice?
Thank you for your time. :)
This is the correct equation for the buoyant force. But you need to be careful about what density to use.
First think of a simple example, like a solid object immersed in water. Would the buoyant force be calculated using the density of the object, or the water?
