I A little doubt regarding specific angular momentum
The discussion centers on whether specific angular momentum remains constant across different osculating orbits of Mars as its orbital elements change over time. It is suggested that specific angular momentum can vary depending on changes in the orbit's parameters, particularly the latus-rectum. The conversation also touches on the implications of Kepler's laws, indicating that they may not apply uniformly across different orbits due to external influences. Additionally, a hypothetical scenario is presented where an external force alters a planet's velocity, prompting questions about how to calculate the new orbital parameters. The exchange emphasizes the complexity of orbital mechanics and the need for precise calculations when external forces are involved.
cptolemy
Good afternoon
I just have this little doubt: imagine the osculating orbit of Mars changing slowly in its elements along the centuries. The semi major axis changes, the period, etc.
Is the specific angular momentum allways equal in all the osculating orbits Mars has in those centuries? Or does it changes with the elements change? That is, if in a century the orbital semi major axis is 1.2 greater, will the specific angular momentum be the same as the previous?
Is it constant on one 2 bodies orbit even if the semi major axis increases?
Kind regards
JKepler
Astronomy news on Phys.org
I would think that it could change, depending upon the details of the change in orbit. Interacting bodies can exchange both linear and angular momentum.
Consider the expression relating specific angular momentum and the size of the latus-rectum:
$$p = \frac{h^2}{\mu}$$
If the orbit changes affect the latus-rectum, then h must change accordingly.
Likes cptolemy
Good evening
Yes, I agree. Thanks for the feedback. However, in 2 different orbits of the same planet, will the same amount of area done in equal times intervals? The total areas and periods are different. But is the second law applyed, and these two values proportional?
Clear skies
JKepler
If you add or subtract energy from an orbit (rotational or angular) you can expect changes. Kepler's laws for 2-body don't take into consideration the influence external influences.
So I would say no, the laws don't apply between different osculating orbits.
Take an extreme hypothetical example. An external body collides with a planet and reduces its orbital velocity to nil (ignore the unphysical technicalities). After this the area swept out per unit time would be nil.
Thanks for the reply gneill
So hipothetically, if a body with velocity V in a orbit of semi major axis A with an eccentricity of E, when it's at its perigee:
dist = A(1-E) and velocity
V= √μ/A*(1+E)/(1-E)
is reduced to a velocity V' by some momentanious force outside, what will be the new parameters of the orbit (the new A' and E')? How do I translate the velocity variation ΔV (V' - V) in those elements?
Can you help me? Thanks.
JKepler
Given the velocity and distance I'd start by finding the specific mechanical energy ξ for the new orbit, hence the new semimajor axis. Then, if you've got both the radius and velocity as vectors after the change, find the new specific angular momentum ##\vec{h} = \vec{r} \times \vec{v}##. With ##\vec{v}\;,\;\vec{r}\;,\text{ and } \vec{h}## in hand you can find the eccentricity vector.
Note that this is not dissimilar to the Hohmann Transfer situation where a spacecraft intentionally changes its velocity to put it on an intercept orbit for another orbit. The only difference is we don't have the second velocity change to circularize the orbit at the new distance.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
