A man jumps on a platform supported by springs (Work and Energy)
An 80.0-kg man jumps from a height of 2.50 m onto a platform supported by springs, compressing them by a maximum of 0.240 m. The spring constant was calculated to be approximately 285288.9 N/m. The man's speed when he depresses the platform by 0.120 m was determined to be 6.96 m/s, but discrepancies in calculations led to confusion regarding the correct value. The energy conservation principle was applied, but incorrect assumptions about the spring constant and energy equations resulted in erroneous speed calculations.
  • Understanding of gravitational potential energy (PE = mgh)
  • Knowledge of kinetic energy (KE = 0.5mv²)
  • Familiarity with spring potential energy (Uspring = 0.5kx²)
  • Ability to manipulate and solve algebraic equations
  • Learn how to derive the spring constant from energy conservation principles
  • Study the relationship between potential energy and kinetic energy in dynamic systems
  • Explore advanced topics in mechanics, such as oscillations and harmonic motion
  • Investigate the effects of varying spring constants on system behavior
Physics students, educators, and anyone interested in understanding energy conservation in mechanical systems, particularly in relation to springs and motion dynamics.
Chandasouk
An 80.0-kg man jumps from a height of 2.50 m onto a platform mounted on springs. As the springs compress, he pushes the platform down a maximum distance of 0.240 m below its initial position, and then it rebounds. The platform and springs have negligible mass.
What is the man's speed at the instant he depresses the platform 0.120 m?
If the man just steps gently onto the platform, what maximum distance would he push it down?
I start with an energy bar graph
Initial (Top) PE = Final(Bottom) KE+ Uspring
mgh = .5mv2 + .5k\Deltax2
I thought it would be simple from here, but I realized I didn't have a spring constant k. I think I found it though. Since K =N/m, it'd be the same as K=mg/m ?
He compressed it it's maximum length of .240m so...
K=(9.80m/s^2)(80kg)/.240m = 3266.7N/m
So, to answer the first part, I just plug in my givens
(80kg)(9.80m/s^2)(2.50m) = .5(80kg)V^2 + .5(3266.7n/m)(.120m)^2
V = 6.96m/s ?
Total fall of PE of man is mg(h + x). Equate it to U(spring) and solve for k.
so, k spring would equal 2mgh/x^2
and that gives
k=285288.8889n/m
2(80kg)(9.80)(2.62m)/(.120)^2
If I plug this is though
(80kg)(9.80m/s^2)(2.62m) = .5(80kg)V^2 + .5(285288.8889n/m)(.120m)^2
I get a funky answer for V.
Chandasouk said:
so, k spring would equal mg/2.62m =299.23n/m?
and the equation is now
(80kg)(9.80m/s^2)(2.62m) = .5(80kg)V^2 + .5(3266.7n/m)(.120m)^2
V = 7.12m/s ?
No. What is the total energy of the man in the above case?
and that gives
k=285288.8889n/m
the height is h +x which would be the 2.50m +.120m
The above equation of energy should be
(80kg)(9.80m/s^2)(2.50m) + .5(80kg)V^2 = .5(3266.7n/m)(.120m)^2
Now solve for v.
1960J + 40kgV^2 = 23.52024J
40kgV^2 = -1936.47976J
V^2 = -48.411994but u cna't take the square of a negative. Even if i neglect the sign and square it to obtain the answer 6.96m/s, my masteringphysics says it is incorrect
The k value should be
k = 2*m*g*(h + x)/x^2
Find the k value.
K=2(80)(9.80)(2.62m)/(.120)^2
K = 285282.9n/m
(80kg)(9.80m/s^2)(2.50m) + .5(80kg)V^2 = .5(285282.9 N/M)(.120m)^2
V = 1.53m/s ?
Mastering Physics told me this was wrong though?
When you want to find k value, take x = 0.240 m
  • · Replies 58 ·
