A not-so-standard buckling problem
  • Thread starter Thread starter irishmts
    Buckling
1 reply · 2K views
irishmts
Hey guys, this came up in one of my past papers, and I'm not quite sure where to go with it.
The diagram shows an idealized structure consisting of an L-shaped rigid bar structure supported b linearly elastic springs at A and C. Rotational Stiffness is denoted βR and translational stiffness is denoted β. If βR = 3βL2/2, determine the critical buckling load PCR for the structure
PCR = C2EI/L, where C is a constant which depends on the end characteristics of the bar, E is youngs modulus, I is inertia, and L is the length of the bar.
Given that the Bar is simply supported, that meant that Le was equal to L/2 i though, and by Le = L/sqrt(C), that gave C a value of 1/4
My first though was to try and resolve the forces being applied, so I took moments about the point of maximum deflection, L/2, when a force of P is applied, where P<PCR. But I got lost there, because I can't figure out what the moment due to the stiffnesses would be, since they are a ratio due to the force applied/ deflection, and I don't know what deflection there would be at the point the spring is attached to
the wall.To solve this problem, you will need to use the Euler-Bernoulli beam equation. The equation can be written as PCR = (π2EI)/L2. Since the rotational stiffness is given, you can calculate the value of I by using βR = 3βL2/2. Substituting I into the equation, you can then calculate the value of PCR.
