A paradox inside Newtonian world
  • Level: Graduate
  • Thread starter Tomaz Kristan
    Newtonian Paradox
514 replies · 72K views · last reply
Galileo said:
We use Euclidean R^3 to describe problems, it does not mean we live in R^3. Physics happens in the real world (or the laboratory), not in Hilbert space or something.
We know this today. Not so long ago, it was the same thing.
But it is not the question of the real world. It is a problem of a theory, which has a hole.
The so called Naive set theory also had a hole, named Russell's paradox. So they fixed it. At least they hope so, it has been fixed.
If I am right, the Newtonian world is also broken "a little" and needs a fix.
Tomaz Kristan said:
For the third case, there is no singularity anywhere. Small balls supports each other and drag the star closer.
Woah there cowboy. You still haven't proved that yet.
Well, so let we do that, again!
You have the next configuration of spheres on the line, in the Newtonian ideal world.
At 1 mm we have centered a ball of 1 mm perimeter and 1 tone of mass. Next to it, on the left side, we have 0.1 mm perimeter ball, 1/2 tone of mass.
And so on. For every natural another 10 times smaller ball by its perimeter, 1000 times by volume, 2 times smaller by mass and 500 denser, then the right side neighbor.
The whole cascade is 10/9 mm long, weights 2 tons, does not moving anywhere for now.
Far away, on the right side, 10 light years away, on the same line, we have Jupiter, also just resting there.
Every ball is now under the net force of every other ball. Small balls are quite coined by gravity to each other. The gravity from the right side is smaller than from the left, for every ball. The reaction force of the surface prevent them to collapse, of course. So they stay put for now.
While Jupiter feels a tiny gravity toward those balls and has no choice but to go there very slowly.
Before the Jupiter's tidal forces will result a disruption inside this structure, we will see it coming closer and closer. The spheres inside the structure will not move anywhere.
What do you need to drag Jupiter? Enough balls. Infinite number of them, arranged as above. And with a very modest mass.
Of course, NOT in a real world. In Newtonian abstract world, only.
How could you not agree?
If you are referring to relativity, that's not what I meant. Mathematics and physics are both able to stands on their own, since they are in essence separated disciplines in the sense, for example, relativity (curved spacetime) has not disproved Euclidean geometry (you can't disprove axioms, certainly not with physics, it's meaningless). Nor can a mathematically abstract construction (like the one you proposed) falsify a logically consistent physical theory, only experiment can do that.
So treat a physical theory from a physical viewpoint. Functions that are continuous everywhere, but nowhere differentiable are nice, but don't use it to describe as the trajectory of a particle (without due thought anyway).
I got the feeling you got a more mathematical background and in a much less extend physics.
I can find similar 'problems' in any other physical theory.
That's mathematics, not physics which I believe to be independent of the assumptions of set theory, choice axioms or continuum hypotheses.
I'm not surprised if Newton knew of similar constructions, but disregarded them on physical grounds.
I don't see them that many. A few, dealing with the infinite mass.
Galileo said:
That's mathematics, not physics which I believe to be independses.
An axiomatic theory is under fire. Doesn't matter the real world here, a bit!
Who knows? He forgot to tell us about this one, for sure.
You still haven't proved that. You haven't shown how the accelleration of the mass is derived. You certainly haven't included a far off mass to the right in your calculations yet.
And each and every mass(an infinite amount of them), will be pulled to the right by Jupiter. There could be a problem here.
I'm stubborn that way. But you'll find an equation or two usually helps to move me. That is, if they can be solved.
Galileo said:
Point is: A physical theory provides a framework to work with. To give insight in Nature and to predict what we can know. We use Euclidean R^3 to describe problems, it does not mean we live in R^3. Physics happens in the real world (or the laboratory), not in Hilbert space or something.
Well, we have different points of view here. Normally, a physical theory is in fact a mathematical theory, with an axiomatic setup, which describes a certain toy world. This theory can now face 2 kinds of difficulties: it can be confronted with intrinsic difficulties as a mathematical theory, and it can be confronted with disagreement with experiment.
If it is in disagreement with experiment (that means, things happen in the toy world of the theory which happen observably differently in the real world, in the lab), then it is a theory which has been empirically falsified. it could have been correct, but it just isn't our world.
However, if it has an internal problem, then it isn't even a universal theory. It can then be at most a kind of effective model that applies more or less in certain "real-world" situations, but there is no consistent, well-defined toy world that goes with it, unless we can add axioms which eliminate the cases that make offense (and hence, in fact change the physical theory).
What the OP is claiming (in my opinion, correctly), is that up to now it was assumed that Newtonian mechanics DID have a consistent structure, and hence DID have a toy world associated with it, only, the real world wasn't completely like that. Now, it seems that it doesn't even have a toy world in the first place. That means, it is not conceivable that there could have been a universe in which Newton's laws are absolutely valid.
The point is in fact that an inconsistency has been derived.
You have an axiomatically non-forbidden setup for which two contradictory answers to its solution (motion) can be constructed, and which all respect all axioms of the theory.
Yes, but again, you have a point of infinite volume mass density.
I'm starting to think that that is the problem.
I don't get it... Wouldn't the balls move towards Jupiter as well?
Every standard Newtonian mass point has an infinite density. Here, in the ball case we have an infinite density out of the structure. Nowhere inside the complex.
It would, if there were a finite number of balls. This way, every ball has a left companions, which easily overweights the Jupiter's gravity. They are much smaller, but very much closer, too.
Well, the density is becoming infinite as you progress to the left. The density is M/V which is 2^-n/10^-n = 5^n, so things are becoming infinitely dense. You could reduced the ball mass, but what would that do to the gravity calculation?
This is correct, but in standard Newtonian physics (with gravity forces only), you can replace every point mass by a sphere with finite density, as long as no trajectory comes closer than the radius of the sphere. So with a point mass distribution which has a finite lower boundary on inter-point distances, you could in principle replace them by spheres with radius = half of the lower boundary. Note that this doesn't even violate Poincare's recurrence theorem, because you could even introduce *shrinking* spheres of which the constant radius, at a certain time, is always half of the "distance of closest encounter". As such, the dynamics is not perturbed, and at any finite time, the volume density is finite with a global upper boundary.
In your construction, you don't have that, because arbitrary high densities are present from the start.
I don't see, in which section of space, we have an infinite density here. It goes over every fixed number, but still remains finite everywhere, except in the point "the rightest point of the biggest ball minus 10/9", outside the structure.
Another peculiarity.
No, no. I have! A few post higher I gave exactly this case.
Yes, every ball does have a finite density. But, which density is the largest?
No ball has the largest density. No ball is the leftmost. No natural is the biggest.
That's the "beauty" of the infinty.
Despite there being infinite balls inbetween 1mm and 10/9mm there is a FIRST at 1mm. The first ball would be feeling no gravity from his left.
Unless I'm still misunderstanding?
Assuming you have an infinite line of balls forever extending so that one always does have a bigger one to the left then my reply would be that we don't know how to properly define infinity. You can prove all sorts of things if infinity was a tangible value. But it's not. You can't have 'infinity' balls.
I don't think so. There is, at a given time, no upper bound to the volume density in all of space. For each given value of volume density, you will find a ball which has a higher density.
This means that I can find a sequence of points in a compact space, x_n, such that rho(x_n) > N for any N ; in other words, I have a sampling of the function rho which diverges and hence rho itself diverges.
In my description, at each given t, there is an upper density in all of space (that is, the entire density function in all of space is bounded). That bound can increase as a function of t, but for a given t-value, there can be an upper bound.
For each given t-value, you cannot find a divergent sampling of rho.
rho(x) < Max(t).
That's exactly what it means, for the density to diverge.
Yes. Density goes over every rho, just as natural numbers go over every N.
Still, every natural is finite, as every density in a finite volume is finite in this structure. You can't show me a finite volume with an infinite density inside the structure.
Nothing illegal here, at all! At least not for the Newtonian world.
In real physics, that is a different matter, of course. You can't get arbitrary high density in the real world.
The density is diverging, it is becoming infinite, as are all the forces on every particle. There are an infinite number of particles so to find the rate of change of the center of mass, we need to sum the rates of change of every mass. But all the numbers involved here are divergent so we no longer have the ability to find the value of the infinite sum.
In order to say that the center of mass do not move, or moves to the left, you must in fact compute this movement, or the accelleration of it instead. It's not enough to make an argument without any mathematics at all, or with only half the mathematics present. You must show your calculations if you wish to make a conclusion about the accelleration. If you do, you will find that you obtain a divergent sums, something that isn't mathematically well defined.
I do not care for divergent densities. Why should I?
Ever smaller mass, ever closer distance, ever greater forces - but so what?
It is by no way something illegal.
The calculations? What calculations? They are simple, almost trivial, when we talk about this "touching balls" example.
Case pretty much closed, I reckon.
You're right. So I`ll just wait for experimental confirmation of the prediction that the center of mass in this construction will go to the left. Then the theory can be adjusted.
Even an axiomatic physical theory is not pure mathematics. It is not as strict. As I said: A certain intelligence has to be used when applying the theory to problems.
There's quite a few of them though. The calculations are as you say, relatively straightforward. There may be a slight issue with the answers though.
Before you go, if you could just throw down those equations, for the sake of completeness if nothing else. I'd just like to say I saw them. You'll forgive an old man his idosyncracies.
Ah ? To me an axiomatic physical theory is a mathematical theory + a rule to link the mathematical objects in it to observations (which, in the case of Newtonian physics, is rather trivial).
ObsessiveMathsFreak,
Very well.
1 - do you agree that the force from the RIGHT side is always finite, for every ball?
2 - do you agree that the force from the LEFT side is always SMALLER than TWICE the immediate left neighbor's gravity force? [As the immediate left neighbor contains half of the mass on the left side, for every sphere.]
What means, that we have a finite force everywhere?
Do you agree then, that those forces are all balanced by the surface reaction force of every ball?
(Now, is it normal, that the tex preview doesn't work? So I can't write down this as a bunch of formulae!)
That's the idea, I am also certain. It's no doubt, in fact.
I think the problem lies in that you cannot have 'infinite balls'
