Staff Emeritus
- 28
One practical use is to back up your claim that the axioms contradict each other.Tomaz Kristan said:What's the use of a rigor, if the axioms contradicts each other?
If I was merely interested in refuting your original PDF, a perfectly sufficient refutation would be to quote the passage
(*) the center of gravity of anybody cannot be accelerated, unless some external force is applied to it
and point out that you have not justified it.
Alternatively, I could point out the fact that even if the above statement is true, your scenario involves a configuration of particles, not a body, so (*) doesn't apply.
But if had presented a valid argument with all due rigor, then (presumably) such objections could not be made.
But I'm not interested in refuting you, I'm trying to explain where you went wrong in reacting to the result of your argument. When we boldly venture forth using intuition as our judge of validity, rather than rigor, we have to face the fact we will make mistakes.
For example, we might attempt to apply some concept outside of its domain of validity -- one would typically view your original PDF as a demonstration that that particle configuration is outside of the domain of applicability of (*).
The advantage of rigor, here, is that theorems come with explicit hypotheses, and you can actually check whether a theorem is applicable to a given situation.
One of the points I was making earlier is that NL is not a formal system. Newton's laws are conceptual. It really doesn't make sense to ask if NL is self-contradictory: such questions only make sense for particular formalizations of NL.I am saying, I see it in ZF+NL.
And although you have not formalized NL, you have (roughly) stated two axioms that you would include (any possible set of values is an admissible configuration of particles, and the center of mass axiom holds for any configuration of particles), neither of which are related to Newton's three laws. So not only have you not shown NL to be contradictory, you haven't even really made progress towards that goal.
