A position of stable equilibrium, and the period of small oscillations
The discussion focuses on calculating the period of small oscillations around a stable equilibrium point, specifically at x = -a, using the potential function V(x). Participants derive the force from the potential using its gradient and establish the relationship between force and acceleration, leading to the differential equation of motion. The correct form of the equation is established as ##\ddot{y} + \omega^2 y = 0##, where ##\omega## is to be determined from the constants involved. The conversation emphasizes the importance of Taylor expansion and proper substitution to derive the necessary equations.
  • Understanding of potential energy functions and their gradients
  • Familiarity with differential equations, specifically harmonic oscillators
  • Knowledge of Taylor series expansion for approximations
  • Basic concepts of force and acceleration in classical mechanics
  • Study the derivation of the harmonic oscillator equation from potential energy functions
  • Learn how to apply Taylor series for approximating functions near equilibrium points
  • Explore the physical interpretation of the gradient of potential energy
  • Investigate methods for solving second-order differential equations in mechanics
Students of physics, particularly those studying classical mechanics, and anyone interested in understanding oscillatory motion and the mathematical modeling of physical systems.
Davidllerenav
A particle of mass ##m## moves under the action of a potential
##V(x)=\frac{cx}{x^2+a^2}##
where ##a## and ##c## are positive constants. Find the positions of stable equilibrium and the period of the small oscillations around those points.
The equations of the harmonic oscillator:
##\ddot{x}=\omega^2x=0##
Period: ##\tau\simeq \frac{2\pi}{\omega}##
I tried by taking the derivative of the potential to find the critic points and the I took the second derivative to find which of those points are minimum points. I found that the point is ##x=- a##. I don't understand how to calculate the period, since I haven't seen anything about the harmonic oscillator.
What force acts at x? So what is the acceleration there?
The potential force?
There is a force resulting from the potential, yes. How is it obtained from V(x) algebraically?
It is the gradient, right?
Yes. So what is that as a function of x?
Well, it is the vector that contains the partial derivatives as coordinate functions, but I don't know its physical meaning.
There seems to be only one dimension here, so just the derivative... which is?
The slope of the tangent line at that point of the curve.
Yes, yes... but write the actual function of x.
##v'(x)=\frac{a^2c-x^2c}{(x^2+a^2)^2}##
Right, so what is the acceleration at x?
I don't know, sorry.
From posts #5 and #11 you know the force, and you are given the mass.
So, the force is ##v'(x)=\frac{a^2c-x^2c}{(x^2+a^2)^2}=m A ##, where ##A## is the acceleration. so ##A= \frac{m(a^2c-x^2c)}{(x^2+a^2)^2}## right?
Retry that last step.
Sorry, I noticed my mistake. ##A= \frac{a^2c-x^2c}{m(x^2+a^2)^2}##
Ok, so write that as a differential equation. Then consider that you are interested in small perturbations from x=-a.
I haven't seen differential equations yet, so I have no idea how to do that.
The relevant equation you quoted (##\ddot x=...##) is a differential equation.
Yes, I know, but I have't take that class yet. My teacher said that it wasn't necessary to solve the differential equation to solve this problem.
Yes, you do not have to solve the differential equation because the relevant equations you posted show how to write the period down directly from the differential equation without solving it. But you still need to get the acceleration equation you have in post #11 into the form ##\ddot x+\omega^2x=0##. This will involve making an approximation for x close to the equilibrium value you found.
This will be a lot easier if you replace x by equilibrium value plus a variable displacement.
How can I find the approximation? Using a taylor polynomial?
Yes.
haruspex said:
Yes.
Ok, and of what degree?
Just the first term.
I think that the polynomial is ##F=mA=v'(a)+v''(a)(x-a)##, it would be ##ma=0+\frac{c}{2a^3}(x-a)## right?
I assume the a on the left should be A, the acceleration, not to be confused with the given a, a coordinate.
Almost right, but you have a sign error.
Well, I thought that that ##a## was supposed to be the value I found, ##x=-a##.
In post #27 you correctly wrote mA= In one equation, A being the acceleration, but in the next equation you changed it to ma=.
  • · Replies 32 ·
