A problem involving Newton's second law.
47 replies · 5K views · last reply
Those values don't look right.
When the system is static at equilibrium, mass Mb pulls on the string with weight Mb*g. So that's the tension in the string, as you've written.
Twice this force (2T) is balanced by the weight of Ma and the force due to the spring. So write
2T = Ma*g + k*xi
Find xi.
You don't need any force or tension equations to find the amount by which the spring length changes when Mb is displaced. The displacement of Mb is coupled to the displacement of Ma and the spring via the pulley system. How much does Ma move for a given movement of Mb?
2T=Ma*g +k*xi,
subbing in values xi = 0.27m
now this is the part where I'm confused- if the string is inextensible then isn't the displacement of Ma and the spring the same value as the displacement of Mb?
Clever_name said:
2T=Ma*g +k*xi,
subbing in values xi = 0.27m <--- Looks a bit high. Check the calculation.
No. There is a mechanical advantage involved, since there's two segments holding up the Ma pulley and only one holding the Mb mass. Check the operation closely. Draw a detailed figure with accurate lengths and measure them if required (choose your own scale and initial lengths).
2SA=SB, that is to say that the vertical motion of B is twice the vertical motion of A
for the calculation i got
(2(98.1)-2(-9.81))/800 = 0.27m
Why the "-" on the 9.81? At the top of the spring, the 2T from Mb is pulling upwards, while Ma and the spring pull downwards. Considering force magnitudes, Ma*g should sum with k*xi.
oh yes, sloppy on my part. so the new calculation comes out as 0.221m. so am i correct in saying 2SA=SB?
Yes.
Ok just to double check my working here is my final attempt:
(1/2)kxf^(2)-(1/2)kxi^(2)=(1/2)Ma*va^(2)+(1/2)Mb*vb^(2)
now i have xi = 0.221 and thus xf must equal double that so that is 0.442
now i have Va=-Vb/2
subbing this into the equation and solving i get
5.25Vb^(2)-58.6092=0, so vb comes out at 3.3412m/s
it also seems odd to me that i never used the fact that block B was pulled down 0.5 m from the rest position in this problem.
gneil can i just get you to confirm my working please as i have no answer key to this question.
xf is not double xi. It's xi plus however much the spring is stretched due to the movement of Mb.
xi represents the initial, equilibrium stretch of the spring. When Mb is moved away from equilibrium, the spring is stretched an additional amount that depends upon how far Mb is moved. That's where your ratio SA/SB comes in.
now i have Va=-Vb/2
Yes, the velocity relationship is okay.
so 2SA=0.5, then SA = 0.25 so Xf = 0.221+0.25=0.471
That looks better.
so (1/2)kxf^(2)-(1/2)kxi^(2)=(1/2)Ma*va^(2)+(1/2)Mb*vb^(2)
then subbing in real values, (1/2)(800)(0.471)^(2)-(1/2)(800)(0.221)^(2) = (1/2)(2)(vb^(2)/4)+(1/2)(10)(vb^(2))
simplifying i get 5.25Vb^(2)-69.2=0
solving this however i get imaginary numbers.
Really? I see real roots. Try again.
