Is This Process Markovian and What Is Its Transition Matrix?
  • Thread starter Thread starter russel
The discussion revolves around determining whether a given process involving two machines is Markovian and finding its transition matrix. The key point is that the number of machines operating on day n, denoted as X(n), depends only on the state of the previous day, X(n-1), which aligns with the Markov property of first-order conditional independence. Participants emphasize the importance of proving that P(X(n+1) | X(1),...,X(n)) equals P(X(n+1) | X(n)), suggesting that this simplification demonstrates the Markovian nature of the process. The transition matrix has been identified, indicating that the probabilities can be derived from the relationship established in the problem. Overall, the process is confirmed to be Markovian based on its dependency structure.
russel
Hello there,
I'm stuck at a problem on markov chains... Could anyone help?
Here it is:
There are two machines that operate or don't during a day. Let $$X(n)$$ be the number of machines operating during the n-th day. Every machine is independently operating during the n-th day with probability $$\frac{1+X(n-1)}{4}$$. Show that the process $$\{ X(n):n=1,2,...\}$$ is markovian and find its transition matrix.
Hey russel and welcome to the forums.
You need to show us what you've tried and what you are thinking.
Markov chains primarily have to have valid probabilities and then need to satisfy 1st order conditional dependence.
So the first hint is that first order conditional independence says that P(X1 = a, X2 = b, X3 = c, blah blah, Xn = whatever | X0 = x) = P(X1 = a|X0 = x). In other words only the current state depends on what happened just before and no more.
What have you thought about for this expression?
I tried to prove that P(X(n+1) | X(1),...,X(n))=P(X(n+1) | X(n)) but I can't. Must I use the P(A|B)=P(A,B)/P(B) ? Is it easier to prove that has independent increments and, therefore, it's markovian? The funny part is I found the transition matrix...
Could I just say that the probability X(n) depends only on X(n-1) (if you see the given equation), so it is markovian?
You can equate this long expression with your (X(n) - 1)/4 and then show that only X(n) matters which cancels all the rest of the terms.
Usually what happens in the independent cases is that if something is independent then P(C and D) = P(C)P(D). In many of these proofs you get an expression with you get P(E)P(D)/[P(C)P(D)] = P(E)/P(C) and P(E) = P(X1 = a, X0 = b) and P(C) = P(X0 = b).
In your case though you are given that it only depends on X(n) so you can just use this result directly, but in the future it's important to note that for many Markovian problems you will need to show independence like in the above scenario so that you get the right cancellation.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
