Why is the Charge Density Calculation Incorrect?
The charge density calculation for a static charge distribution producing a radial electric field, defined as E = A e^{-br}/r, is incorrect due to a misinterpretation of the electric field expression. The correct form should be E = A e^{-br}/r^2, leading to the charge density ρ = -ε₀Ab/r² e^{-br} + 4πε₀Aδ(r). The term 4πε₀Aδ(r) arises from applying Gauss's law with a spherical Gaussian surface and considering the limit as radius approaches zero, indicating a point charge at the origin.
  • Understanding of electric fields and charge distributions
  • Familiarity with Gauss's law
  • Knowledge of divergence in vector calculus
  • Basic concepts of delta functions in physics
  • Study the application of Gauss's law in electrostatics
  • Learn about the divergence operator in vector calculus
  • Explore the properties and applications of delta functions
  • Investigate the implications of charge density in electrostatic problems
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to electric fields and charge distributions.
wf198349
1. Homework Statement [/b]
A static charge distribution produces radial electric field as follows:
\stackrel{\rightarrow}{E}=A\frac{e^{-br}}{r}\stackrel{\rightarrow}{e_{r}}
A,b are constants,please compute the charge density.
\nabla\cdot \stackrel{\rightarrow}{E}=\frac{\rho}{\epsilon}
\nabla\cdot \stackrel{\rightarrow}{E}=\frac{1}{r^{2}}\frac{ \partial}{\partial r}(r^{2}A\frac{e^{-br}}{r})=\frac{1}{r^{2}}\frac{\partial}{\partial r}(Are^{-br})
But the result is wrong.Can you tell me why?
What result did you get and what did you expect?
The reference answer is
\rho=\epsilon_{0}\nabla\cdot \stackrel{\rightarrow}{E}=-\frac{\epsilon_{0}Ab}{r^{2}}e^{-br}+4\pi\epsilon_{0}A\delta(r)
It looks like there's a typo in the expression for the electric field. I think it should be
\mathbf{E} = \frac{Ae^{-br}}{r^2}\mathbf{e}_r
But how can I get the term 4\pi\epsilon_{0}A\delta(r) ?
Apply the integral form of Gauss's law using a sphere of radius r as the Gaussian surface and take the limit as r goes to 0. From that result, you should be able to deduce a point charge has to reside at the origin.
  • · Replies 32 ·
10K
