Consistency of citation brackets in academic writing
4 replies · 1K views
nomadreid
This is not a contextual question, but a stylistic one; hence it doesn't seem to belong in the other threads.
I am proof-reading a paper, and I am unsure about the way the author uses square brackets for the indication of (numbered) sources. In order not to be quoting a source without authorization or citation, I will make up an example that follows the author's style:
"This solution can be used to develop further examples of the application of this technique [18], [26]. In particular, in [26], the transformations are used as new variables..."
Note that he uses the square brackets in two different ways: in the first case "technique [18], [26]" , he uses them to say "see [18] and [26] for details", whereas in the final case,"In particular, in [26]," he is using the brackets as a substitute for the title etc. of the source. Put another way, the first case is an aside, a parenthetical statement, whereas the second case is used as a noun in the sentence itself. This appears to be to be inconsistent.
Am I being too picky, or if not, what is the solution?
While I am here, the author occasionally (thinking in the structure of his native language) occasionally uses "the obtained solution"; more natural would be something like "the solution thereby obtained", but is "the obtained solution" also acceptable?
Thanks for any guidance.
You are being too picky.
OK, thanks, Vanadium 50. It is certainly easiest to leave the text as is.
I presume your answer goes also for the question about "obtained".
Both forms appear acceptable*. The first uses the past participle of the verb obtain as an adjective to modify solution. Your preferred form retains obtained as a following adverb. Example:
I own the red painted truck.
I own the truck painted red.
*As has been mentioned by grammarians in other threads, much of the grammar and syntactical forms I learned ~60 years ago are effectively obsolete due to numerous changes in predicate and propositional logic. The general term adverb seems safe to apply to most modifiers derived from verbs. :cool:
