A question about dice probability calculation
3 replies · 4K views
TheNaturalStep
A question about probability calculation
What is the probability that the sum from two dices are under 9, i don’t know a fast way to calculate that :(, instead i calculated it manually by listing all possible event.
Divided by the total number of outcomes 6*6=36
And something else that I can not understand,
p=probability that this happen
Case 1
dice (1,1), dice (1,1), <-> is one event <-> 2p
case 2
dice(1,2) and dice(2,1) <-> is two events <->2p
How come case one gets 1 event and 2p when case 2 gets two events and 2p ...
Kindly TNS ...
If you get more than 9(assuming that you meant sum>9 and not equal to 9) you can get (6,3) or (6,4) or (6,5) or (6,6) or (5,5) or (5,4) <---- these gives you the possibilities to get a sum[itex]\geq[/itex]9. NOTE: this follows the order, (dice1,dice2)
so to get (6,3)=[itex]\frac{1}{6}*\frac{1}{3}*2!=\frac{1}{9}[/itex]
since all the possibilities will be similar to that it will simply be [itex]\frac{1}{9}*6[/itex] which is [itex]\frac{2}{3}[/itex] but this is to find P(sum[itex]\geq[/itex]9) so then to find what you want is simply 1-P(sum[itex]\geq[/itex]9)
Case 1
case 2
Kindly TNS ...
If you were calculating the probability of getting a 2 on a pair of dice, there is only one way that can happen. Die "A" is a 1 and die "B" is a 1. Probability of rolling a 2 is 1/36.
If you were calculating the probability of getting a 3 on a pair of dice, there are two ways that can happen. Die "A" is a 2 and die "B" is a 1 or die "A" is a 1 and die "B" is a 2. Probability of rolling a 3 is 2/36= 1/18.
Thank you very much for your replies, i think it is clear now.
Kindly TNS
