A question about water flow rate
3 replies · 3K views
alwindawee
Hi all, I'm doing a experiment at home I'm trying to know how the flow rate on the water height that tossed from a nozzle with 3mm of diameter.
By an other word if there is a relationship between flow and the height please some one explain it to me.
Also I wana to know if the head pressure if the water height that tossed from a nozzle.
thanks in advance.
thanks, russ.
thank you too nvn, I have read the post but did not reach what I need, I think if I explain the problem a little more you could help so this what the problem.
I wana the water go for the desired height and want to know how much flow rate and how much head (Q and H) needed so I can choose the right pump.
And this is the way I imagined the matter:
I applied this formula "s=s0+(v0*t)+(0.5*a*t^2)" and solved for v0 supposing that:
s0=0 .... at the nozzle.
t=1s .... I suppose that water reach the desired height in 1s.
a=9.81 ... the acceleration due to gravity.
finding v0 which is the initial velocity the water tossed with from the nozzle.
Then applying the formula "Flow Rate = 0.25 * pi * (pipe diameter)^2 * velocity"
solving for flow rate I'll find the needed flow rate so I can select the pump.
and for the Head Pressure (H) as I know we can determine the needed H approximately by measuring the distance from the spot that the pump stands to the nozzles tossing hole.
this is the way I calculate things, if it's wrong please help me and by the way I'm a electronic engineering student but like mechanics.
thanks for you response again.
