A question that give wrong answer?
  • Thread starter Thread starter vkash
vkash
Hello!
Today my maths teacher ask a question to all student in class. that was
Code:
f:R-->R
f(x) = (a*x[SUP]2[/SUP]+6x-8) / (a+6x-8*x[SUP]2[/SUP])
f is onto then find the value of [b]a[/b]
after 10 minutes some students answer. every body was wrong.
this question was also answered wrong in many Indian writer's books for many years. Now my teacher tell where we all students were wrong and know i know the correct answer. I just want to show this question to all those persons who love mathematical beauty.I am not intended to get answer for homework help.
So guys try it.
Please don't answer this if you already know this questions truth.
I'm sure if the question was worded properly, then some people would have attempted a solution. Exactly what does "f is onto then find the value of a" mean? Are we looking for a value of "a" such that both the numerator and the denominator can be factored over the reals?
I agree it could be worded more clearly, but it made perfect sense to me (though I could be wrong). "f is onto" means (afaik) "for every real number y, there is some real number x such that f(x)=y".
Onto means co domain of function is equal to range of function. If there comes a number that is in co domain but not in range then it will not remain onto. Finally i mean co domain=range.(it is just hint to for onto not full definition)
If you try this question then post your answer. Not with full method but just tell what your procedure of doing question and final answer.
Let y be any number. If
y= \frac{ax^2+6x-8}{a+6x-8x^2}
then
y(a+ 6x- 8x^2)= ax^2+ 6x- 8
ay+ 6yx- 8yx^2= ax^2+ 6x- 8
(a+ 8y)x^2+ (6-6y)x- (8+ ay)= 0
You can solve that using the quadratic formula. Can you find a specific value of "a" so that has a real solution for any "y"?
then
(a+ 8y)x^2+ (6-6y)- (8+ ay)= 0
I think you mean
(a+ 8y)x^2+ (6-6y)x - (8+ ay)= 0
on the last line. :smile:
Yes, thanks. I will correct it.
then
dear this is the way how every body do it(including me) but this will give you wrong answer[/color]. I don't know what is wrong with this method but it will give you wrong answer.If you are not believing me then find value of a mentioned by HallsofIvy and draw it's curve using any http://www.padowan.dk/graph/Download.php" . You will be confirmed.
Dude this amazing behavior of this question is it's beauty. I am not fool that i ask such easy question. Due to this reason this question was answered wrong in many books for many years. Everybody(who do it wrong) do this as you do.
HINT: think in different way.[/color]
HallsofIvy's approach seems perfectly sound to me; unless you have another valid solution, then you are wrong. Please do show us anything you have though, I'm sure a lot of us would like to see it.
OK, I'll bite. What is the correct way of solving it according to you?? And what do you get as solutions that HOI (perfectly sound) approach doesn't give?
Wait i will give it's answer.
Let more people to try this question.
Answer will given after 12 hours.
Till then keep thinking.
REQUEST+> Don't post answer if you know it's trick.[/color]
Okay, so I'm just going to treat the top equation as a quadratic, and the bottom equation as a quadratic, and then multiply them together.
rac{-b\pm&space;\sqrt{b^{2}-4ac}}{2a}\cdot&space;\frac{2a}{-b\pm&space;\sqrt{b^{2}-4ac}}&space;=.gif
Now I replace the first fraction with a,b, and c with a,6, and -8. Then I replace the second fraction with a,b, and c with -8, 6, and a.
4a(-8)}}{2a}\cdot&space;\frac{-16}{-6\pm&space;\sqrt{6^{2}-4(-8)a}}&space;=&space;\frac{-8}{a}=x.gif
Now you know x, when y is zero, so you just plug into the original equation, and you might get the right answer?
Note: I think we have to do something with that y. I don't think the quadratic equation works when a,b, or c is not constant. I bet we have to use calculus to solve this.
Nvm, the above method is totally bogus.
a+6x−8x^2 cannot equal zero, so we just have to find a value of a that makes it impossible for a+6x−8x^2 to not equal zero.
So, just take the derivative: 6−16x = 0 so x =3/8 the max.
which means that value of a has to be when a+6(3/8)−8(3/8)^2) is less than zero.
I think it's when a is less than -9/8?
We can also just switch the signs on that equation so that we have -(a+6x−8x^2) on the bottom and -(ax^2+6x-8) on top.
The derivative is -6+16x = 0 so the minimum is now, 3/8 = x, which means that value of a has to be when -[a+6(3/8)−8(3/8)^2)] is greater than zero. (+9/8)
the fact that you said "math teacher" made me think calculus
Oh, I think I know what it is know. Isn't it weird how there is an -8 on top where there is an a in the bottom and vise versa? You simply put in a=-8 and the answer is always 1!
((-8)*x^2+6x-8) / ((-8)+6x-8*x^2)=1
-8 is smaller than -9/8 so the calculus was true.
I don't quite get what the question is though.
if this is your first visit to this thread then please try this question before seeing answer.(think different)[/color]
see it's answer.
given equation
y= \frac{ax^2+6x-8}{a+6x-8x^2} and f:R-->R
so denominator will never zero OK.
using shredharanachrya principle D<0 only in that case this possible.
so 36-32*a<0 this implies a&gt; \frac{9}{8}--------------------point 1.
In denominator coefficient of x2 is negative so all the values of a+6x-8x2 will smaller than 0.--------------------point 2.
since denominator value is smaller than 0 for all x so numerator should have all -ve as well as +ve values so that function became onto.
come to numerator how is it's D's nature if it will remain quadratic equation it will either give all the +ve or all the -ve values so a=0 so that it can give all the values +ve as well as negative from here we come to know that a=0.--------------------point 3.
is there any value that satisfy all the condition.
do you got the answer there is no solution for this question.
this is it's beauty friends. this way of thinking is easier and takes less time but everybody didn't think so. due this amazing nature of this question i post it here.
Now real question starts from now why these two methods give different answer even nothing is seeming wrong with method written by HallsofIvy.[/color]
I don't know what tukka(random method) does RandomMystery applies but my solution is correct.
If you did not know why first(given by HallsofIvy) method is wrong then ask this to all the friends(who can answer). If you got the solution then please message answer to me or post that here. I am also searching for it's reason.
This question came in IIT JEE 1996 entrance exam.
I think this is a trick question. If you set a = x you get
f(x) = (x^3+6x-8) / (7x-8x^2)
and this is onto the reals.
SteveL27 said:
I think this is a trick question. If you set a = x you get f(x) = (x^3+6x-8) / (7x-8*x2) and this is onto the reals.
first of all tell me what will happen when x=0. Will it finite. if not then it will not became onto.
every question in mathematics has a trick some are common trick those are called easy questions and some are rare tricks where question became tougher.
it's answer can't be 'x'. why see real question.
A function f:R-->R, where R is set of real numbers, is defined by f(x)= \frac{ax^2+6x-8}{a+6x-8x^2}. Find the interval[/color] values of a for which f is onto. Is function one to one for a=3? justify your answer.
[/color]
this is the photo copy of question that come in 1996 entrance exam. Here a interval of a is asked not variable value.
if you got the reason why HallsofIvy wrong then post that reason here.
HoI's method is perfectly correct. His method will give that the function f is onto if a\geq 2. However, since the function must be entire, it must also hold that a+6x-8x^2 has no roots. But no a\geq 2 satisfies this. So there are no solutions.
see it's answer.
given equation
I thought this expression had to be negative for there not to be any zero roots in the denominator.
a&gt; -\frac{9}{8}
Why isn't that ^ the answer? I don't understand what onto and f:R-->R mean.
If you plug in any number less than -9/8 on any graphing calculator, you will get a continuous function.
What do you mean by "-ve as well as +ve" and what does "the function became onto" mean?
Does D mean denominator?
"how is it's D's nature if it will remain quadratic equation it will either give all the +ve or all the -ve values so a=0 so that it can give all the values +ve as well as negative from here we come to know that a=0"
What does this mean? Where did he get a=0?
I think you can still use the quadratic equation:
gif.latex?x=-\frac{(6-6y)\pm&space;\sqrt{(6-6y)^2-4(a&plus;8y)(8&plus;ay)}}{2(a&plus;8y)}.gif
a has to be a value that makes this expression always true (since you can't take the square root of negative numbers):
[URL]http://latex.codecogs.com/gif.latex?0\leq&space;(6-6y)^2-4(a&plus;8y)(8&plus;ay)[/URL]
I'm not sure what you do next, but maybe you have to sub in y=a*x^2+6x-8) / a+6x-8*x^2 at some point.
a&gt; -\frac{9}{8}
I think either conventions used in your country for function notation is different from that of in IN[/color]DIA[/color]
D is b*b-4ac discriminent of quadratic equation.
f:R->R this mean domain of function is all real number and co domain is also R all real number.
if you have ever drawn curve of f(x)=\frac{ax^2+bx+c}{} then you must have found that it makes a parabola. A parabola can't cover all the values i mean a quadratic equation can't give all -ve as well all +ve values. If a =0 it became straight line which give all the -ve as well as +ve values. that's why i say a=0 for this to give all -ve as well as +ve values.
this is what i was saying.
It's hard or impossible to catch the error in work I can't see. VKash, why don't you post your attempt & I can catch the mistake.
In the original post, it says
"f is onto"
Now, I read f is NOT onto.
So your question is just plain false. The original post asked the impossible.
As asked for the entrance exam, the empty set is a valid interval, a legitimate answer to the entrance exam variation. Please post questions verbatim whenever possible.
To withhold critical information, necessary to solve the question is disrespectful at best. If you want to play games, go to
https://www.physicsforums.com/showthread.php?t=71315"
that is too lengthy to type just do this on your own this is lengthy but not tooooo... lengthy to do in paper.
Errhhh, have you tried WolframAlpha.com?
It will do this level of complexity for you. One can even take results and
The best reason I have so far?
Simply solving the quadratic formula doesn't guarantee solutions for every y. It only guarantees solutions
Or maybe the value one gets for "a", generates a removable discontinuity in the original rational function.
If the discriminant is >0, we know there are two places where the graph crosses the x-axis, which isn't enough to be onto.
The main issue I ran into?
The function has horizontal asymptotes, but never seems to get to or cross the asymptote.
I hope I wasn't too harsh on you.
Bye.
I got a partial answer below, but stopped working when I saw the original post asked an invalid question.
Why is there no answer?
Here's my stab at the answer.
The denominator has zero, one or two roots. The number of roots relates to the number of vertical tangents.
A. One Root, One Vertical Tangent:
... {see other work in this thread}
a = -9/8
A quick graph will show us clearly it is not onto the reals.
B. No Roots, No Vertical Tangents
a < -9/8
The end behavior, lim x->+- oo is a horizontal asymptote. Same asymptote for both +oo and -oo.
lim f = (-9/8)/ -8 = -9/64
Rational functions of polynomials only go to oo at the x=-oo or x=oo or at vertical asymptotes.
Unfortunately, with no vertical tangent, this means the function is bounded.
C. Two roots, Two vertical tangents
a>-9/8
I don't have a conclusive proof.
Let x = c & x = d, where c < d be the roots of the denominator. Vertical tangents appear at x = c & x = d.
(Assume a>0, because if -9/8 < a < 0 we have a similar argument with a vertical flip of the graph.)
The behavior for x<c and x>d is similar. Again both approach horizontal asymptotes as x->+-oo from above. (The rational function is (negative number)/ (negative number), for |x| sufficiently large.)
So we must rely on the graph between the vertical asymptotes, for everything below the horizontal asymptotes. However, choosing a, so the hump in the middle comes high enough is difficult or impossible.
vkash said:
Hello!
Code:
f:R-->R
So guys try it.
The quadratic in the denominator must have complex roots, which occur when a<-9/8. Then f(x) will be analytic, and onto iff the domain of f is ℝ.
I don't think there is such an a. First of all we need a < -9/8. We also need surjectivity, but this will ultimately imply that (a+8)^2 < 0 (if you do the calculations per Halls' method), which is impossible.
Another method is to note that such a function will have horizontal asymptotes, which denies surjectivity.
This is not true in general, consider f(x) = xsin(x). It will require some work to show that it is true for rational polynomial functions.
Bye.
OK! solving quadratic equation does not involve solution always but one should always think about reasons. All rules(as i know) of mathematics are human assumptions so there is answer of all such things that why of why not. You can't say so in physics because there are rules which are made by GOD and we are studying those rules.
why are going to complex maths even thou i have mentioned that f is from real number to real number.If you are intended to just help me by saying all this is possible in complex math then OK! else. see real question .I posted that later in this thread.
Oh why some people create this complex mathematics? Is it branch of mathematics? I say so because it violate some rules of mathematics(I have read a very little complex maths).[/color]
vkash said:
OK! solving quadratic equation does not involve solution always but one should always think about reasons. All rules(as i know) of mathematics are human assumptions so there is answer of all such things that why of why not. You can't say so in physics because there are rules which are made by GOD and we are studying those rules.why are going to complex maths even thou i have mentioned that f is from real number to real number.If you are intended to just help me by saying all this is possible in complex math then OK! else. see real question .I posted that later in this thread.
Hello. Suppose that the denominator quadratic DOES HAVE real roots, say for x=x1 and x=x2. Then if the domain of f is all of ℝ: f(x1),f(x2) →∞. So that there aren`t y1,y2∈ℝ s.t., f⁻¹(y1)=x1, f⁻¹(y2)=x2. Hence, f will not be onto.
NOTE: If f(x)=y then f∘f⁻¹(y)=y.
I don't think this is true. Just because f fails to be defined at a couple of points, how does that show there exists y1 and y2 that don't get hit by some value of x?
In the joke solution I gave in post #15, I said to take a = x. Of course that's a "what color is the bear?" answer, not a math answer.
If you do that, you get f(x) = (x^3+6x-8) / (7x-8x^2) which blows up at two points. But if you graph it, you'll see that it's onto! The three connected components of the graph overlap to cover the y-axis.
In general, rational function can be onto even if the denominator has real zeros and therefore blows up at a couple of points. I didn't prove that, I just looked at a graph ... so it's possible I'm totally wrong here.
Here's the graph I got from the Grapher app in OS X.
  • #31
Here's the graph I got from OS X Grapher.
First, `a` (parameter) cannot by chosen to be the independent variable (x). Second, the graph of f(x) = (x^3+6x-8) / (7x-8x^2) has pole at x=0. So as you can see from the graph there is no `y`∈ℝ s.t. y=f(0).
When the denominator quadratic has no real roots then f (a quotient of two polynomials) is onto. Just the monomial term in the numerator quadratic guarantees that.
  • #32
vkash said:
Hello!
Code:
f:R-->R
So guys try it.
Just look at the essential part, and ignore the commentary:approve:
  • #33
I said about three times that this is a joke solution ... but the resulting function is very interesting anyway.
Just look at the graph. There's clearly a zero at around x = 1 or so, where the right hand component of the graph crosses the x-axis. What do you make of that?
You keep saying that there's a pole at 0, which of course is true. But it does not therefore follow that NO value of x gives f(x) = 0.
  • #34
f(x) = (x^3+6x-8) / (7x-8x^2) has pole at x=0, and for `x` very close to zero f(x)~ -8/7x. Hence, as x->0- f-> +∞ and as x->0+ f-> -∞. If the resolution of your graph were better you could see this behaviour more clearly.
  • #35
It has nothing to do with the behavior of f at x = 0. Better study the definition of onto. The graph crosses the x-axis at around x = 1. That means f takes the value zero for at least one value of x. So f is onto.
To see that f is onto, look at the y axis. You can see that you can pick any point on the y-axis and a horizontal line through it will intersect the graph of f.
You are fixating on the pole at 0 but that has nothing to do with whether f is onto. You are confusing domain and range.
  • #36
The original post says that the domain of f is all of ℝ.
  • #37
Well yes, you are correct about that. But the function f I gave is onto. I hope you see that. I ran it through the equation solver at http://www.quickmath.com/webMathematica3/quickmath/equations/solve/basic.jsp to find the real root.
This example shows that a rational function can have a pole (two, in fact) and still be onto.
  • #38
I tried a = -2, and the resulting function does not have a real zero. In fact there are two solutions, both complex. So you are right that with the denominator never zero, you get an analytic rational function, but not necessarily onto the reals when the domain is restricted to the reals.
Do you have a specific value of 'a' that you have shown to produce a function that is onto the reals when the domain is restricted to the reals?
  • #39
Why is VKash's original reasoning incorrect?
In my opinion, the test makers are being overly literal or legalistic.
I. See
Possible solution to NOT meet the criteria. This function IS ONTO. but does not answer what the question is asking.
Quick reasoning for "onto":
i. The Limit as x->(3-sqrt(33))/8 from left, the vertical tangent, is +oo & the limit from the right is -oo.
ii. Quotients of polynomial functions are continuous everywhere they are defined.
iii. So the example, f with a=3 is onto (-oo, +oo).
See II & III for why it's not an answer.
II. In many books, you'll find
f:R->R, g:R->R
f(x)= 1/(x-2) or g(x)= x(x-4)/(x-4) + sin x
of course we realize x=2 is not in the domain of f and x=4 is not in the domain of g, but it's a bit of mathematical shorthand or informality to call R, the domain.
III. So if a=3, would meet the criteria for onto. This is why it's acceptable usage in many textbooks, not so excessively formal.
However, under the exam question, they are apparently expecting & requiring a more formal (IMHO, excessively formal) interpretation.
The fact that the question askers require every single possible number in all of R to give a legitimate y value rules out Possible solution As far as I can tell, according to the test makers, any vertical tangent or removable discontinuity in the quotient means it's not a solution for f. So under the test makers interpretation, the denominator can never be zero ever for a removable discontinuity.
IV. I believe the previous posts make clear why if the denominator never reaches zero, it's not onto. Another time, I may elaborate on that.
  • #40
Errghh, is there way to edit a previous post?
These are clarifications to my July 17, 6:43am post.
To clear up some responses, to my post.
A. "function is bounded"
Remember all this in context, no vertical tangents, a<-9/8
I should say the function has a bound.
For example, y =x^2 has a bound; y>=0 for all x.
I can probably prove both bounded, meaning it has upper and lower bound based on both numerator and denominator have degree 2, but that is too complicated & unnecessary.
Of course, I know, but that goes beyond the scope of this thread.
Some work- not that much. Our specific situation is much simpler. The following is a ROUGH DRAFT OR SKETCH OF A PROOF also called a proof plan.
Pick some a <-9/8
for all a<-9/8 it can be shown the denominator is always negative.
Likewise, for any a<-9/8, it can be shown the numerator is always negative.
So for a<-9/8, f is always positive.
This establishes 0 as a lower bound for f, when a<-9/8.
Interested readers can fill in the details.
Response to SteveL,
I only see a link to the solver & am unsure exactly what you put in. For future reference, please post the link to your actual solution. WolframAlpha maybe more effective.
Also, the first mention I see of a=x as a joke, is quite a while after the mention of a =x.
It's true for our original question, but in general, this is false
y=x^4/(x^2+1)
One rule of thumb, divide the highest two powered terms, pretend the "degree" of the rational is the degree of the result. This will give some insight into the behavior especially, when the denominator has no real roots.
To VKash,
I think all the talk of complex numbers so far, can safely be rephrased as "no real numbers".
  • #41
I........
[size=+2]where am i wrong[/size]. I have used basic rules not any big trick.
According to SteveL27 a=x ((x^3+6x-8) / (7x-8x^2) ) is an answer. stevel does 0 comes in domain of function((x^3+6x-8) / (7x-8x^2)) Hu. as given in question 0 should in domain of function but that is not in your answer. so stop making unwanted comments on a function that is not valid for condition i propose.
You still think my explanation is incorrect(in this post about stevel) then find domain range of this function f(x) = 1/x does 0 in it's domain.
sorry that i make post little late.
keep talking on this question because debate make us better.
Mathematics is an assumption[/color]
  • #42
nickalh said:
Response to SteveL,
Here's a Wolfram Alpha link for the case of a = -2. Note that -2 is less than -9/8.
http://www.wolframalpha.com/input/?i=(-2x^2+++6x+-+8)+/+(-2+++6x+-+8x^2)+=+0
Now you see that there are no real solutions. So matphysik's claim that a < -9/8 gives an onto function is not true. Now, there may be SOME value of a < -9/8 that works, but till we hear from matphysik, we have to reject his claim. He noted that with the denominator never zero, the rational function is analytic. That's true. But I don't see how it follows that f must then be onto the reals as a function of the reals.
  • #43
VKash,
The very first step HallsOfIvy gave on one of the very first responses gets us into trouble.
then
For x-values, which make the denominator zero, the first line is invalid. See II & III on my Tuesday, 9:43am post. However, for the second line, those x-values masquerade as solutions to the original question.
see
False solutions a=2, x=1 and a=14, x=-1
Essentially, it boils down to you're original method may include vertical tangents, which is technically not f:R->R.
This appears related to the discriminant of a quadratic function.
However, b^2 -4ac becomes
36-4*(-8)a<=0
36 plus 32a <=0
So I'm unsure what you're getting at.
The main reason, HallsOfIvy's original solution doesn't work
I also think we're beating a dead horse. I'll try to move on.
Bye.
  • #44
Nobody has suggested a value of 'a' that makes f onto. Nobody has proved that no such 'a' exists. This is an open problem. matphysik has suggested a promising approach, but I believe there's a counterexample to his claim that any a < -9/8 works. Perhaps some other value works.
An open problem isn't a dead horse in my opinion.
  • #45
It can be proven algebraically that no such a exists as by hall's of ivy's method.
Alternatively using calculus, one can simply look at the limit as x approaches infinity. The function will have horizontal asymptotes for any 'a' which makes surjectivity impossible.
  • #46
  • #47
nickalh said:
In general, surjectivity, also known as onto, does not require horizontal asymptotes.
See
http://www.wolframalpha.com/input/?i=y+=+(cos+x)/x"
Similar, examples of polynomial rational functions, may exist especially with higher degree polynomials.
Uhm, that function does not have domain R. A continuous function f : R --> R with horizontal asymptotes on both sides will not be surjective.
  • #48
Hi. If the function is analytic, then it`s continuous.
x↦logx takes (0,∞) onto ℝ. Rewrite, y=f(x)=(ax²+6x-8)/(a+6x-8x²)≡(x-A)(x-B)/(x-C)(x-D). Then, logy=log(Re[(x-A)(x-B)]-log[(x-C)(x-D)]). So then, ONE possibility for f(x) being onto occurs if ALL of {A,B,C,D} are complex numbers. In this way we will not get log(0+) for all x∈ℝ.
  • #49
nickalh said:
I think we're beating a dead horse. I'll try to move on.
Bye.
I also think so.
Actually my main motto for this post was to know why method written by HallsOfIvy is wrong and now i got that.
I does not post it(real answer and my question) directly in first post because i want to know is there any mathematical dude here who think so. unfortunately no such dude come here to answer.
  • #50
CORRECTION:
f (as given) takes ℝ into ℝ so that, y=f(x)=Re{f(x)}. Let z↦logz take ℂ\(-∞,0] onto ℂ. Write, f(x)=(ax²+6x-8)/(a+6x-8x²)≡(x-A)(x-B)/(x-C)(x-D). For `a` to be determined such that f takes ℝ onto ℝ. ONE possibility for f(x) being onto occurs if ALL of {A,B,C,D} are complex numbers.Then,
Re[logf(x)]=Re[log(x-A)+...-log(x-D)] takes ℝ (x) into ℝ\(-∞,0] (f(x)) onto ℝ (Re[logf(x)]).
If z=eʷ and w=u+iv then |z|=e^(Re(w)) and log|z|=Re(w). Let w=logf(x).
