Can a Moving Rod in a Magnetic Field Produce a Voltage?
A moving rod in a magnetic field can produce a voltage due to the motion of charge carriers within the rod, as described by the motional electromotive force (emf) principle. When the rod moves perpendicularly through the magnetic field, the magnetic force acts on the free electrons, causing a separation of charge and resulting in a voltage difference across the ends of the rod. This phenomenon is consistent with Faraday's law, which relates the induced emf to the rate of change of magnetic flux, even when considering a single rod instead of a complete circuit loop.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with the concept of motional electromotive force (emf)
  • Basic knowledge of magnetic fields and forces on moving charges
  • Proficiency in applying the right-hand rule for magnetic forces
  • Study the derivation of the motional emf formula for a single conductor
  • Explore applications of Faraday's Law in electromagnetic devices
  • Investigate the effects of varying magnetic field strengths on induced voltage
  • Learn about the practical implications of induced emf in electrical engineering
Students in physics, electrical engineers, and anyone interested in understanding electromagnetic induction and its applications in technology.
Durato
OK, so I forget the exact problem, since it was on a test, but here's basically what it stated.
There's a magnetic field pointing directly into the page. A vertical rod, perpendicular to the magnetic field, is placed in it and is moved with a velocity v to the right.
Then, they show you a bunch of rods moving in different direction (but in the same plane of the paper). They ask you 'which one will produce the greatest voltage between both ends of the rod.'
I don't have pictures, since it was a test question, but what is bothering me is how a moving rod in a magnetic field can produce a voltage in the first place. Faraday's law states that V = rate of change of flux, but how is flux changing in this case? The rod is always in the magnetic field so the magnetic flux is always constant.
When i did look this up in the book, they 'derived' it by imagining that the rod was attached to a u-shaped loop. As the rod moved to the right, the area of the enclosed region would increase, thus increasing flux. But I don't see how this applies to a separate rod of metal.
Thanks!
At first I thought this question was about the Yankees playing at Boston.
The way to think about flux causing an emf is to consider whether or not field lines are cutting through the wire. IF it is just a single wire, then as it moves across a field, lines are continuously cutting through the wire. If it is a loop moving through a field, then the entire loop must be considered: a line that "cuts-in" can be canceled by a line that "cuts-out" of the loop.
Since the wire by itself is part of a larger loop (the circuit), then you can see that if the entire apparatus was moved through the field, then there would be no net change in flux. But since the straight wire is the only part of the circuit that moves across a field, then the flux inside the entire loop is obviously increasing.
I'm a little confused. They derived the voltage induced in a rod by pretending the rod was in a circuit (u-shaped metal with rod connecting the sides). But how does this apply to a single rod?
Hi Durato,
You don't have to derive the motional emf formula by assuming a loop. You can also derive by just considering a single rod. As the rod moves to the right, the charges inside the rod are moving to the right, and so the magnetic force will push them to one end of the rod (so one end becomes positive and the other becomes negative).
However, the electric force will try to pull these charges back together. When the electric and magnetic forces are in equilibrium, you can derive the motional emf formula.
Does this answer your question?
THink of the basic right hand rule. A charge moving through a magnetic field will feel a force. If you move a conductor through a magnetic field, the free electrons are the moving charges,and they will feel a force that pushes them to one end of the rod, as alphysicist pointed out. The emf is the same whether or not the current is allowed to flow (well, that's the simple version; as usual, the "real world" gets more complicated).
Thx! I think I get the concept now. All i need is to derive the equation and see that it is the same as the one derived using the conceptual loop.
