How Do You Calculate the Velocity Components of a Sailboat Affected by Wind?
  • Thread starter Thread starter iSimply
The discussion revolves around calculating the velocity components of a sailboat affected by wind, specifically focusing on the eastward and northward components of velocity during different time intervals influenced by motor and wind accelerations.
  • Mixed
  • Participants explore the addition of vector components for acceleration and question the correct time intervals for the wind's effect on the boat's velocity.
  • There is a focus on clarifying the timing of when the wind starts and stops affecting the boat, as well as how to incorporate the motor's contribution to the velocity.
  • Some participants suggest breaking down the velocity calculations into segments based on the phases of wind influence.
Participants are actively refining their understanding of the problem, with some providing corrections to earlier assumptions about time intervals and components. There is a collaborative effort to clarify the equations for both east and north components of velocity, with acknowledgment of previous errors and adjustments being made.
There is an ongoing discussion about the assumptions related to the timing of the wind's effect and the motor's operation, which may not be fully defined in the original problem statement.
iSimply
A sailboat is traveling due east, with a speed V=Vinit at time t = 0 and a constant eastward acceleration A(motor). From a time t = t(gust) to a time t=t(calm), a gust of wind gives the boat an additional acceleration A(wind) at an angle 60o North of East. Find an expression in terms of the quantities given for the North and East components of the boat's velocity at the time t(calm).
Just basic 2 dimensional kinematic like
Vfs= Vis + Ast
Sf= Si+ Vis(t) + 1/2 As(t)^2
3. The Attempt at a Solution
I thought about this and think East components = Vinit + ( A motor + A wind (1/2)) (tcalm-t0)
and North components = A wind (√3/2) (tcalm-t0)
I mostly added the vectors of A wind and A motor, I am not sure if that is right. Please clarify or correct me if I am wrong, thank you.
Why from t0 to t(calm)? Is that the correct time period in which the wind is blowing?
Again, is that the time that the wind acts?
I wasn't sure if from t0 to Tgust there was a time difference.
If the point where Tgust happens then it would only be from Tcalm-Tgust.
Is the rest of it correct?
If they say it starts at tgust then you shouldn't assume tgust=t0
The rest is correct, but write out the equation for the East component so I can see that you do it correctly.
Well for the East component we have a Vinit and 2 acceleration component acting on it. Which are Amotor and Awind.
And we know that Awind is 60 degree north east so the Awind in the east direction would be equal to Awindcos60degree
So Velocity for the East component is equal to Vinit+ (Amotor + Awind cos 60) (tgust-tcalm).
Does it look correct?
Did we only turn on the motor on once the wind starting blowing?
No... :(
That was the part where I was confused and wasn't sure how to approach it.
I know that from t0 to tgust the motor was running, but I wasn't sure how to incorporate it.
V east= Vinit + (motor (t0-tgust))+ (motor + wind)(tcalm-tgust)...
Write it in pieces. What is the velocity once the wind starts blowing? Then what is the velocity after the wind stops blowing?
Also I just noticed one more small error. You wrote (tgust - tcalm), does anything seem wrong with that?
Yeah it should be (tcalm - tgust) good catch.
Well it goes from Vinit+ (motor(tgust-t0)) when the wind start.
Then once it stop then wouldn't it be that plus ( motor + windcos 60)(tcalm-tgust).
so it would be Vinit + (motor (tgust-t0))+ (motor +windcos 60)(t calm-tgust).
Is that right?
iSimply said:
Is that right?
Yep :) (You can simplify it slightly because t0=0)
Oh and an edit my to North Component it should be = A wind (√3/2) (tcalm-tgust)
since no north component was acting it on from t0 until tgust.
You are awesome, thank you for the help!
Indeed
You're welcome
  • · Replies 20 ·
