Calculating Orbital Velocity and Radius Using Energy Conservation
The forum discussion focuses on calculating orbital velocity and radius using energy conservation principles. The user attempted to derive the radius and final velocity of a satellite after accounting for air drag, using the equations of circular motion and gravitational force. The calculations yielded a final radius of approximately 7,987,281.75 meters and a final velocity of 7,063.11 m/s, which was about 2% off from the expected value of 6,905 m/s confirmed by Chegg. The discussion also highlights the importance of considering both kinetic and potential energy in such calculations.
  • Understanding of gravitational force and circular motion equations
  • Familiarity with energy conservation principles in physics
  • Knowledge of integral calculus for work-energy calculations
  • Basic understanding of LaTeX for formatting equations
  • Study the derivation of orbital mechanics equations, focusing on gravitational force and centripetal acceleration
  • Learn about energy conservation in orbital dynamics, specifically how to apply it to satellite motion
  • Explore the effects of atmospheric drag on satellite orbits and how to calculate them
  • Practice using LaTeX for formatting complex equations in physics
Students studying physics, particularly those focusing on mechanics and orbital dynamics, as well as educators looking for examples of energy conservation applications in satellite motion.
cwill53
A satellite with mass 848 kg is in a circular orbit with an orbital speed of 7223 m/s around the earth. After air drag from the earth's upper atmosphere has done ##-1.91\cdot 10^{9} ## J of work on the satellite it will still be in a circular orbit. What are the speed in radius in this new orbit? Hint: You must take account of both kinetic AND potential energy, initially and finally, because both the speed AND the orbit radius change.
$$F_{C}=F_{G}$$
##U_{grav}=- \frac{GMm}{r}##
$$\Delta K+\Delta U+\Delta U_{int}=0$$
I know this problem can be solved using energy conservation, but I tried another method that I don't know is correct or not, but yielded a similar result to what my classmates got:
$$F_{C}=F_{G}\Rightarrow \frac{mv^{2}}{r}=\frac{GMm}{r^2}$$
$$\frac{v^2}{r}=\frac{Gm}{r^2}\Rightarrow r=\frac{GM}{v^2}$$
Using the mass of Earth ##M_{E}=5.974\cdot 10^{24}## kg,
##r_{initial}=\frac{\frac{6.674\cdot 10^{-11}m^3}{(kg\cdot s)}(M_{E})}{(7723m/s)^2}=7642161.141m\Rightarrow g## is now ##6.827 m/s^2##
##-1.91\cdot 10^{9} ## J =##\int_{r_{i}}^{r_{f}}\frac{GM_{E}m}{r^2}dr=-GM_{E}m[\frac{1}{r_{f}}-\frac{1}{r_{i}}]##
##-1.91\cdot 10^9J=\frac{GM_{E}m}{r_{f}}+4.424\cdot 10^{10}J##
##\Rightarrow r_{f}=7987281.75m##
##v_{f}=\sqrt{\frac{GM_{e}}{r_{f}}}=7063.1108 m/s##
The answer was about 2% off from the one everyone else got, which was Chegg confirmed to be like 6905 m/s.
By the way, how do you make the integral sign bigger?
You seem to have equated the total loss of energy to the loss of just the potential energy. Reread the hint.
cwill53 said:
Homework Statement:: A satellite with mass 848 kg is in a circular orbit with an orbital speed of 7223 m/s around the earth. After air drag from the Earth's upper atmosphere has done ##-1.91\cdot 10^{9} ## J of work on the satellite it will still be in a circular orbit. What are the speed in radius in this new orbit? Hint: You must take account of both kinetic AND potential energy, initially and finally, because both the speed AND the orbit radius change.
Relevant Equations:: $$F_{C}=F_{G}$$
Your approach won't work, as you've done it.
In the relationship between work, force and displacement,
W = \int_{x_0}^{x_1} \vec F \cdot \vec {dx},
keep in mind that \vec F and \vec{dx} are vectors. The differential work dW is the dot product of the two. In other words, if dW is to increase, \vec F and \vec{dx} need to be more-or-less in the same direction.
But that's not the case in your application, for this particular problem. Here, the Earth's atmosphere's drag force on the satellite is perpendicular to Earth's radius, not parallel to it. So for this problem (as you've treated it),
\vec F \cdot \vec{dr} = 0.
So you'll need to take a different approach.
-- Regarding the size of the integral sign:
In Physics Forums (PF), the smaller integral sign is automatically used when doing inline \LaTeX. If you want to make it larger, put it on it's own line.
Inline notation:
or
[itex] ... [/itex]
To put it on its own line,
or
[tex] ... [/tex]
Inline notation:
or
[itex] ... [/itex]
or
[tex] ... [/tex]
Oh, now I see where I went wrong. Thanks for the thorough explanation.
  • · Replies 30 ·
