- 14,792
- 7,438
Any book or review paper on BM, or the original Bohm's two papers from 1951.A. Neumaier said:But no reference is given...
It is a statistical effect. See e.g.A. Neumaier said:I'd be interested to know what happens in a relativistic version of Bohmian mechanics. Do the microscopic particle positions respect Einstein causality, or is the latter considered to be a statistical effect?
He wrote several books, which you conflate. You seem to refer to his book Thermodynamic Formalism. The Mathematical Structures of Equilibrium Statistical Mechanics whereas I was referring to https://www.amazon.com/dp/9810238622/?tag=pfamazon01-20.atyy said:You are clearly not familiar with the work you cite! Ruelle's resulst are axiom A results!
Demystifier said:So, if I understood you correctly, the first spin is EPR real (because it is measured by Alice), the second spin is also EPR real (because it is measued by Bob), but both spins together are not EPR real (because nobody observed both spins). Is that what you are saying?
Because they are the same in the EPR definition of realism as deterministic. They are of course not the same in the philosophical definition of realism I gave that you normally use when referring to realism.Demystifier said:This is non-realism. But I never understood why so many people think that non-determinism and non-realism is the same.
Thanks. I didn't know this paper. When viewed in the large ##N## limit, does your many-particle relativistic quantum mechanics reproduce macroscopic continuum mechanics? Or is it just a proposal studied for its own sake?Demystifier said:It is a statistical effect. See e.g.
https://arxiv.org/abs/1205.1992
This is not a thread to discuss and correct notions of ''real'' but one on Bohmian mechanics. Please keep your remarks on topic.RockyMarciano said:You keep conflating the broadest philosophical meaning and the EPR meaning of "real".
Yes (but not in a way you naively expect).A. Neumaier said:When viewed in the large ##N## limit, does your many-particle relativistic quantum mechanics reproduce macroscopic continuum mechanics?
I was answering a direct question by the official Bohmian around here.Either the question is on topic and then the answer is, or the question is off topic and then you should make your comment addressing the question.A. Neumaier said:This is not a thread to discuss and correct notions of ''real'' but one on Bohmian mechanics. Please keep your remarks on topic.
In which way, then?Demystifier said:Yes (but not in a way you naively expect).
I did it already: https://www.physicsforums.com/posts/5665529/ and posts #95-#97. But you didn't listen.RockyMarciano said:I was answering a direct question by the official Bohmian around here. Either the question is on topic and then the answer is, or the question is off topic and then you should make your comment addressing the question.
This is just playing semantically with the distinction between inferences and assumptions. The premise of BI that measurements in the same direction determines perfect anticorrelation measurements pressumes simultaneous existence of the spin measurement angles at certain initial time t, therefore determinism despite of how common sense this premise might appear. The fact is that this premise is implied by "no action at a distance" i.e. classical locality principle when applied to spacelike separated regions. So here the classical notion of locality based on simultaneity is used, i.e. the classical determinism with an initial state at time t=0 with a Cauchy surface of simultaneous measurements outcomes.zonde said:Ok, then here are some of Bell's own words:
"It is important to note that to the limited degree that determinism plays a role in the EPR argument, it is not assumed but inferred. What is held sacred is the principle of “local causality” or “no action at a distance”. Of course, mere correlation between distant events does not itself imply action at a distance, but only correlation between the signals reaching the two places. These signals, in the idealized example of Bohm, must be sufficient to determine whether the particles would go up or down. For any residual undeterminism could only spoil the perfect correlation. It is remarkably difficult to get this point across, that determinism is not a presupposition of the analysis."
In the context of EPR, EPR realism is clearly well defined, so why not use it? The meaning "not solipsism" is the broadest philosophical meaning and this is indeed confusing in the quantum context of EPR.And please try not to use "realism" in QM context unless you mean "not solipsism" because it's very confusing what you mean with it. (is it determinism here? or causality? or particles having spin at all times?)
Classical fluid consists of many classical mutually non-entangled particles. Quantum mechanically, each of these particles can be considered to have it's own wave function, the width of which is of the order of Bohr radius. By Ehrenfest theorem, the "center" of each of these wave packets moves by classical laws. In BM, each of these wave packets is filled with a few pointlike particle (depending on the kind of atom one talks about). Within packet the Bohmian motion of the particles is highly non-classical. Nevertheless, since each particle is confined within the packet (the center of which moves classically), this non-classical motion looks pretty classical at large macroscopic distances.A. Neumaier said:In which way, then?
And then in #99 you asked a question as off-topic from the OP as the ones Demystifier have been asking me.A. Neumaier said:I did it already: https://www.physicsforums.com/posts/5665529/ and posts #95-#97. But you didn't listen.
It is my thread and my question in #99 was about an aspect of Bohmian mechanics quite related to the title. But you answered in #131 again an offtopic post by zonde to one of your off-topic posts and contribute in this way to the pollution of the thread.RockyMarciano said:And then in #99 you asked a question as off-topic from the OP as the ones Demystifier have been asking me.
I don't see how starting from your relativistic multiparticle version, this gives macroscopic continuum mechanics. Reference?Demystifier said:Classical fluid consists of many classical mutually non-entangled particles. Quantum mechanically, each of these particles can be considered to have it's own wave function, the width of which is of the order of Bohr radius. By Ehrenfest theorem, the "center" of each of these wave packets moves by classical laws. In BM, each of these wave packets is filled with a few pointlike particle (depending on the kind of atom one talks about). Within packet the Bohmian motion of the particles is highly non-classical. Nevertheless, since each particle is confined within the packet (the center of which moves classically), this non-classical motion looks pretty classical at large macroscopic distances.
Ok, if it comes down to this I'm out.A. Neumaier said:It is my thread
I've just explained it in the post above, but in a sketchy way. If you don't see it I would need to write a long article with all details for you, which I don't plan to do. There is no reference because it is considered obvious, not only in the BM community, but also in the clasicallity-from-decoherence community.A. Neumaier said:I don't see how starting from your relativistic multiparticle version, this gives macroscopic continuum mechanics. Reference?
Strange. In statistical mechanics, it is considered nontrivial to derive macroscopic continuum mechanics from microscopic multiparticle theory, but apparently in BM everything trivializes so that none of the difficult things must be done. It is this attitude that was criticised by Reinhard Werner in the article quoted in post #1,Demystifier said:There is no reference because it is considered obvious, not only in the BM community, but also in the clasicallity-from-decoherence community.
Reinhard Werner said:The Bohmian perspective seems to be the opposite. You don’t care about the hard problem, but only about that last, utterly trivial bit.
It is of course non-trivial (either with or without BM) to do it rigorously. But it is trivial if you don't insist on rigor.A. Neumaier said:In statistical mechnaics, it is considered nontrivial to derive macroscopic continuum mechanics from microscopic multiparticle theory, but apparently in BM everything trivializes so that none of the difficult things must be done.
I have noticed that many of your questions about BM totally miss the point. To exaggerate a bit, many of your questions sound to me like: OK, string theory is the theory of everything, so how string theory explains the protein folding? Reference?A. Neumaier said:I don't see how starting from your relativistic multiparticle version, this gives macroscopic continuum mechanics. Reference?
Therefore I ask the questions that I expect a fundamental theory to solve. I am not interested in foundations that are not even trying to address these questions. They are fake foundations, in my view.Demystifier said:BM is supposed to be a fundamental theory
You effectively tell me that I shouldn't be interested in Bohmian mechanics. I had noticed this myself over the course of years. But I still ask these questions so that others can see it, too.Demystifier said:I have noticed that many of your questions about BM totally miss the point.
RockyMarciano said:Ok, if it comes down to this I'm out.
I am not sure whether you are really interested in BM (or only interested in disproving* BM), but if you are, it seems to me that you are interested for wrong reasons. From a Bohmian point of view, standard QM is an effective theory emerging from more fundamental BM. For many high-level questions it is much more appropriate to use effective theory instead of fundamental theory. Different physical questions need different effective theories. See the paper "More is different" by Anderson I linked above. So yes, in a way I am telling you that you shouldn't be interested in Bohmian mechanics, just as I would tell you that you shouldn't be interested in quantum electrodynamics if you asked me about radiation from antenna (for which classical electrodynamics is a much better tool).A. Neumaier said:You effectively tell me that I shouldn't be interested in Bohmian mechanics.
I am highly interested in good and strong foundations of quantum mechanics. As part of my efforts there I look at what each interpretations contributes to the understanding of the questions that I find good foundations should settle. In particular, I ask questions, give answers, and criticize in this spirit.Demystifier said:I am not sure whether you are really interested in BM (or only interested in disproving* BM)
This is because I share the sentiment of Reinhard Werner expressed in the quotes in post #1 that, unfortunately, there is very little positive to say about BM. Querying for possible positive things that I might have overlooked only confirms that. These queries are dismissed with comments such asDemystifier said:(*I have never seen that you said anything positive about BM.
Demystifier said:In all these years you either criticize it, or ask questions which sound like "Ha, I bet you can't answer this one!".
I have even less positive to say about Many Worlds. It has not even a mathematical basis but is pure speculation.A. Neumaier said:unfortunately, there is very little positive to say about BM.
DrChinese said:I don't think so. On the other hand, demystifier is on record saying "... it cannot be said that there exists a well-defined relativistic QM." There's always an out!
But now
http://xxx.lanl.gov/pdf/quant-ph/0609163v2
he thinks there is one. Though it is a nonstandard one that does not make the same predictions as QED. That's why I had askedDemystifier said:It is a statistical effect. See e.g.
A. Neumaier said:When viewed in the large ##N## limit, does your many-particle relativistic quantum mechanics reproduce macroscopic continuum mechanics? Or is it just a proposal studied for its own sake?
Because this is the least test a theory different from QED must pass to be taken seriously. Unfortunately, the answer I got was onlyA. Neumaier said:I don't see how starting from your relativistic multiparticle version, this gives macroscopic continuum mechanics. Reference?
although the question is about the relativistic multiparticle theory itself and not the Bohmianization of it. Bohmian mechanics may be confident that they predict the same relativistic results as the theory that they Bohmianize, but if the latter makes wrong predictions then the Bohmian version makes the same wrong predictions.Demystifier said:There is no reference because it is considered obvious, not only in the BM community, but also in the classicality-from-decoherence community.
If so, why are you still so much interested in it? Why do you waste your time? Why don't you just ignore it?A. Neumaier said:there is very little positive to say about BM
I had answered this already:Demystifier said:Why don't you just ignore it?
A. Neumaier said:As part of my efforts there I look at what each interpretations contributes to the understanding of the questions that I find good foundations should settle. In particular, I ask questions, give answers, and criticize in this spirit.
I agree that this must happen in BM, but it seems to me that this makes BM superdeterministic. In a deterministic theory, the assumption ##P(\lambda,\vec a,\vec b) = P(\lambda)## is usually taken to model the free choice of the experimenters. If BM can only reproduce QM by taking the measurement process into account, it appears to deny this free choice.Demystifier said:When the measurement setup is changed, then it is ##P(\lambda)## that gets modified.
I'm glad that you asked it. Indeed, there is no free choice in BM because it is a fully deterministic theory. However, it is not superdeterministic theory. In a superdeterministic theory the initial conditions are fine tuned in order to simulate a law which does not really exist as a law. (For instance, 't Hooft studies superdeterministic local hidden variables for QM, where the appearance of non-locality is simulated by fine tuned initial conditions for local hidden variables.) There is no such fine tuning of initial conditions in BM. Similar to classical mechanics, BM is fully deterministic but not superdeterministic.rubi said:I agree that this must happen in BM, but it seems to me that this makes BM superdeterministic. In a deterministic theory, the assumption ##P(\lambda,\vec a,\vec b) = P(\lambda)## is usually taken to model the free choice of the experimenters. If BM can only reproduce QM by taking the measurement process into account, it appears to deny this free choice.
